Interface problem Ecuflash V1.31 and V1.32
Fri Sep 07, 2007 7:59 pm
by brick41183
I have a 2002 Eclipse GT. v1.29a works, but when i try to use v1.31 and v1.32. It will not connect to the ecu. I have uninstalled it three times. Nothing. Also delete the Ftdi's and reinstalled them. Nothing. Any help Thanks
Sun Sep 09, 2007 2:33 pm
by brick41183
Anybody? In the 3G Eclipse forums there are a few of us that can't get it to connect. Looking for HELP PLEASE!!! Even installed the new V1.32 and the samething.
When i go to read the ecu, i click on the button to read, click on 2001-2005 Mitsubishi 3rd Gen/EVO7-8, (before i got a prompt screen with v1.29a, now i don't), then it say unable to connect....
Trying to get the program to work so i can try and download a GSX rom.
Tue Sep 11, 2007 7:08 am
by OrlandoGT
bump...same problem here. 2000 Eclipse GT with the H8 processor.
Tue Sep 11, 2007 2:31 pm
by brick41183
OrlandoGT, what is your cable read out in the v1.32 or v1.31? Should read something in the lower right corner of ecuflash when the cable pluged in.
Wed Sep 12, 2007 12:12 am
by BarryC.
why are you selecting 3rd gen evo7/8
all H8 processors were only in the 2nd gen evo 5/6 ???
Wed Sep 12, 2007 7:05 am
by gteclass
the rom i have defined from a 2000 elcipse gt was from a fed spec emmissions car. my cali spec car wont read. Is there a chance that the cali read routine is different?
ps. I am using the evo 5/6 setting and it still hangs on "sending init sequence 2".
Wed Sep 12, 2007 3:16 pm
by brick41183
Just trying to use v1.32 to connect to my 2002 Eclipse GT, used the 3g evo7/8 selection. I only know one person at the moment that has it working with his 2001 Eclipse and 15 that can't get it to work with their 2001+ Eclipse.
I've also tried to use the other selections and the samething. Unable to connect.
Fri Sep 14, 2007 5:11 am
by gteclass
my cable still reads and flashes my friends 2003 gts eclipse no problem. it still wont read my 2000 though.
Mon Sep 17, 2007 2:54 pm
by brick41183
Well tried a friends cable. Work fine with v1.32. Doesn't make any sense why my doesn't. My cable works perfect with v1.29. Just wondering if it has to do with the drivers in my cable not being recogized in the newer version of ecuflash. If the make sense to anybody.
My cable is around a year old. My friend's cable is two months old. That is suppose to be the difference, but i'm being told that nothing has change in the making of the cables. They are all the same. So is mine not working?
