ecu locked?
Sat Aug 04, 2007 3:29 pm
by 03scoobysnack
I was able to read the stock map off of my ecu, but when i tryed to load up the new map i got the low voltage message and could not load the map. I then appiled 12v to the flash block, and tried again loading the map and reading the ecu but i go the denso02 boot load message and unable to load kernel, kernel flash disabled.
Is it possible that i f**k up the ecu and locked so i cant acces the ecu and write or read any maps.?
This is the only result i get after jumping the 12v wire.
1452 byte kernel read.
196608 byte image read.
ecu image loaded.
denso02_bootloader_cmd_start
rkrv: preamble 1 no response
<< PROCESS COMPLETE >>
I also have a portmon log of when i tryd accessing the ecu.
i couldnt and the attachment with the log so if any could help me out i could email them the log. idk it might have attached i tried to.
PLEASE HELP Me
Thnk you
Jordan
Sat Aug 04, 2007 5:46 pm
by Freon
There are limits depending on the file extension. You can attach it as a .txt text file.
Sun Aug 05, 2007 9:06 am
by 03scoobysnack
Here is the log file
Sun Aug 05, 2007 9:13 am
by 03scoobysnack
why is the file 0 bytes i have it saved on my comp @91kb so wtf...
Sun Aug 05, 2007 9:17 am
by 03scoobysnack
Sorry it is so long i couldn't get it to upload. Could someone tell me what all this means and why i can't access my ecu.
cheers
0 7:57:19 PM ecuExplorer.exe IRP_MJ_CREATE VCP0 SUCCESS Options: Open
1 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_QUEUE_SIZE VCP0 SUCCESS InSize: 16384 OutSize: 16384
2 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
3 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
4 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
5 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
6 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
7 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
8 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
9 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
10 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_BAUD_RATE VCP0 SUCCESS Rate: 4800
11 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_CLR_RTS VCP0 SUCCESS
12 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
13 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_LINE_CONTROL VCP0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
14 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_CHAR VCP0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
15 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_HANDFLOW VCP0 SUCCESS Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
16 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_TIMEOUTS VCP0 SUCCESS RI:-1 RM:0 RC:0 WM:50 WC:0
17 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_WAIT_MASK VCP0 SUCCESS Mask: CTS DSR
18 7:57:19 PM ecuExplorer.exe IRP_MJ_FLUSH_BUFFERS VCP0 SUCCESS
19 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
20 7:57:19 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
21 7:57:19 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
22 7:57:23 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
23 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_SET_QUEUE_SIZE VCP0 SUCCESS InSize: 16384 OutSize: 16384
24 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
25 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
26 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
27 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
28 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
29 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
30 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
31 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
32 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_SET_BAUD_RATE VCP0 SUCCESS Rate: 9600
33 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_CLR_RTS VCP0 SUCCESS
34 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
35 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_SET_LINE_CONTROL VCP0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
36 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_SET_CHAR VCP0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
37 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_SET_HANDFLOW VCP0 SUCCESS Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
38 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_SET_TIMEOUTS VCP0 SUCCESS RI:-1 RM:0 RC:0 WM:50 WC:0
39 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_SET_WAIT_MASK VCP0 SUCCESS Mask: CTS DSR
40 7:57:23 PM ecuExplorer.exe IRP_MJ_FLUSH_BUFFERS VCP0 SUCCESS
41 7:57:23 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
42 7:57:23 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
43 7:57:24 PM ecuExplorer.exe IOCTL_SERIAL_CLR_DTR VCP0 SUCCESS
44 7:57:24 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
45 7:57:24 PM ecuExplorer.exe IRP_MJ_WRITE VCP0 SUCCESS Length 3: 4D FF B4
46 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
47 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 3: 4D FF B4
48 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
49 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
50 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
51 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
52 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
53 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
54 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
55 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
56 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
57 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
58 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
59 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
60 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
61 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
62 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
63 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
64 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
65 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
66 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
67 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
68 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
69 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
70 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
71 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
72 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
73 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
74 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
75 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
76 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
77 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
78 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
79 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
80 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
81 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
82 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
83 7:57:24 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
84 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
85 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
86 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
87 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
88 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
89 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
90 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
91 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
92 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
93 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
94 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
95 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
96 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
97 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
98 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
99 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
100 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
101 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
102 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
103 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
104 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
105 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
106 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
107 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
108 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
109 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
110 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
111 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
112 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
113 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
114 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
115 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
116 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
117 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
118 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
119 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
120 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
121 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
122 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
123 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
124 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
125 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
126 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
127 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
128 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
129 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
130 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
131 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
132 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
133 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
134 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
135 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
136 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
137 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
138 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
139 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
140 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
141 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
142 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
143 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
144 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
145 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
146 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
147 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
148 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
149 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
150 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
151 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
152 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
153 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
154 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
155 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
156 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
157 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
158 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
159 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
160 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
161 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
162 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
163 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
164 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
165 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
166 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
167 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
168 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
169 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
170 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
171 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
172 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
173 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
174 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
175 7:57:25 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
176 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
177 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
178 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
179 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
180 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
181 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
182 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
183 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
184 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
185 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
186 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
187 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
188 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
189 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
190 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
191 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
192 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
193 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
194 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
195 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
196 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
197 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
198 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
199 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
200 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
201 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
202 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
203 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
204 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
205 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
206 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
207 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
208 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
209 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
210 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
211 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
212 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
213 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
214 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
215 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
216 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
217 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
218 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
219 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
220 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
221 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
222 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
223 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
224 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
225 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
226 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
227 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
228 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
229 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
230 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
231 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
232 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
233 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
234 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
235 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
236 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
237 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
238 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
239 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
240 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
241 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
242 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
243 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
244 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
245 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
246 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
247 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
248 7:57:26 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
249 7:57:26 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
250 7:57:27 PM ecuExplorer.exe IOCTL_SERIAL_CLR_DTR VCP0 SUCCESS
251 7:57:27 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
252 7:57:27 PM ecuExplorer.exe IRP_MJ_WRITE VCP0 SUCCESS Length 3: 4D FF B4
253 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
254 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 3: 4D FF B4
255 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
256 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
257 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
258 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
259 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
260 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
261 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
262 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
263 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
264 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
265 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
266 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
267 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
268 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
269 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
270 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
271 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
272 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
273 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
274 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
275 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
276 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
277 7:57:27 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
278 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
279 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
280 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
281 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
282 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
283 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
284 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
285 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
286 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
287 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
288 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
289 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
290 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
291 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
292 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
293 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
294 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
295 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
296 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
297 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
298 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
299 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
300 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
301 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
302 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
303 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
304 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
305 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
306 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
307 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
308 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
309 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
310 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
311 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
312 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
313 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
314 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
315 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
316 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
317 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
318 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
319 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
320 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
321 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
322 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
323 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
324 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
325 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
326 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
327 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
328 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
329 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
330 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
331 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
332 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
333 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
334 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
335 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
336 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
337 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
338 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
339 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
340 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
341 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
342 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
343 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
344 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
345 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
346 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
347 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
348 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
349 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
350 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
351 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
352 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
353 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
354 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
355 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
356 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
357 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
358 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
359 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
360 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
361 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
362 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
363 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
364 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
365 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
366 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
367 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
368 7:57:28 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
369 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
370 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
371 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
372 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
373 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
374 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
375 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
376 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
377 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
378 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
379 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
380 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
381 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
382 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
383 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
384 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
385 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
386 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
387 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
388 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
389 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
390 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
391 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
392 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
393 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
394 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
395 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
396 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
397 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
398 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
399 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
400 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
401 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
402 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
403 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
404 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
405 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
406 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
407 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
408 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
409 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
410 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
411 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
412 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
413 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
414 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
415 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
416 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
417 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
418 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
419 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
420 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
421 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
422 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
423 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
424 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
425 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
426 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
427 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
428 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
429 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
430 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
431 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
432 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
433 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
434 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
435 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
436 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
437 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
438 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
439 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
440 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
441 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
442 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
443 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
444 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
445 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
446 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
447 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
448 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
449 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
450 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
451 7:57:29 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
452 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
453 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
454 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
455 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
456 7:57:30 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
457 7:57:30 PM ecuExplorer.exe IOCTL_SERIAL_CLR_DTR VCP0 SUCCESS
458 7:57:30 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
459 7:57:30 PM ecuExplorer.exe IRP_MJ_WRITE VCP0 SUCCESS Length 3: 4D FF B4
460 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
461 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 2: 4D FF
462 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 1: B4
463 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
464 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
465 7:57:30 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
466 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
467 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
468 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
469 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
470 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
471 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
472 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
473 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
474 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
475 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
476 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
477 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
478 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
479 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
480 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
481 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
482 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
483 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
484 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
485 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
486 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
487 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
488 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
489 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
490 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
491 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
492 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
493 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
494 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
495 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
496 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
497 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
498 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
499 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
500 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
501 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
502 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
503 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
504 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
505 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
506 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
507 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
508 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
509 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
510 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
511 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
512 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
513 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
514 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
515 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
516 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
517 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
518 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
519 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
520 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
521 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
522 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
523 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
524 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
525 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
526 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
527 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
528 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
529 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
530 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
531 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
532 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
533 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
534 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
535 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
536 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
537 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
538 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
539 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
540 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
541 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
542 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
543 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
544 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
545 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
546 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
547 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
548 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
549 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
550 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
551 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
552 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
553 7:57:31 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
554 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
555 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
556 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
557 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
558 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
559 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
560 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
561 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
562 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
563 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
564 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
565 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
566 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
567 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
568 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
569 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
570 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
571 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
572 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
573 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
574 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
575 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
576 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
577 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
578 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
579 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
580 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
581 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
582 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
583 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
584 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
585 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
586 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
587 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
588 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
589 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
590 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
591 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
592 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
593 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
594 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
595 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
596 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
597 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
598 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
599 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
600 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
601 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
602 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
603 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
604 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
605 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
606 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
607 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
608 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
609 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
610 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
611 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
612 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
613 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
614 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
615 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
616 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
617 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
618 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
619 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
620 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
621 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
622 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
623 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
624 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
625 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
626 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
627 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
628 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
629 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
630 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
631 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
632 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
633 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
634 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
635 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
636 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
637 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
638 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
639 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
640 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
641 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
642 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
643 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
644 7:57:32 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
645 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
646 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
647 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
648 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
649 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
650 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
651 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
652 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
653 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
654 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
655 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
656 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
657 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
658 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
659 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
660 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
661 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
662 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
663 7:57:33 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
664 7:57:33 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
665 7:57:33 PM ecuExplorer.exe IOCTL_SERIAL_CLR_DTR VCP0 SUCCESS
666 7:57:33 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
667 7:57:34 PM ecuExplorer.exe IRP_MJ_WRITE VCP0 SUCCESS Length 3: 4D FF B4
668 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
669 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 3: 4D FF B4
670 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
671 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
672 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
673 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
674 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
675 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
676 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
677 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
678 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
679 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
680 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
681 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
682 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
683 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
684 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
685 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
686 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
687 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
688 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
689 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
690 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
691 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
692 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
693 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
694 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
695 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
696 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
697 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
698 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
699 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
700 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
701 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
702 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
703 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
704 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
705 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
706 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
707 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
708 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
709 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
710 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
711 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
712 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
713 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
714 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
715 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
716 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
717 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
718 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
719 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
720 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
721 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
722 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
723 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
724 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
725 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
726 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
727 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
728 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
729 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
730 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
731 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
732 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
733 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
734 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
735 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
736 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
737 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
738 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
739 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
740 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
741 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
742 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
743 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
744 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
745 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
746 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
747 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
748 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
749 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
750 7:57:34 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
751 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
752 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
753 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
754 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
755 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
756 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
757 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
758 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
759 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
760 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
761 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
762 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
763 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
764 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
765 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
766 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
767 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
768 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
769 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
770 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
771 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
772 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
773 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
774 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
775 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
776 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
777 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
778 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
779 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
780 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
781 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
782 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
783 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
784 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
785 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
786 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
787 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
788 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
789 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
790 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
791 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
792 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
793 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
794 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
795 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
796 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
797 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
798 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
799 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
800 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
801 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
802 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
803 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
804 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
805 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
806 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
807 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
808 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
809 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
810 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
811 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
812 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
813 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
814 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
815 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
816 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
817 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
818 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
819 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
820 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
821 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
822 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
823 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
824 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
825 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
826 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
827 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
828 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
829 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
830 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
831 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
832 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
833 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
834 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
835 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
836 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
837 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
838 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
839 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
840 7:57:35 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
841 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
842 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
843 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
844 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
845 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
846 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
847 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
848 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
849 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
850 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
851 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
852 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
853 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
854 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
855 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
856 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
857 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
858 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
859 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
860 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
861 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
862 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
863 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
864 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
865 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
866 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
867 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
868 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
869 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
870 7:57:36 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
871 7:57:36 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
872 7:57:36 PM ecuExplorer.exe IOCTL_SERIAL_CLR_DTR VCP0 SUCCESS
873 7:57:37 PM ecuExplorer.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
874 7:57:37 PM ecuExplorer.exe IRP_MJ_WRITE VCP0 SUCCESS Length 3: 4D FF B4
875 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
876 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 2: 4D FF
877 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 1: B4
878 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
879 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
880 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
881 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
882 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
883 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
884 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
885 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
886 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
887 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
888 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
889 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
890 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
891 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
892 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
893 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
894 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
895 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
896 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
897 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
898 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
899 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
900 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
901 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
902 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
903 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
904 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
905 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
906 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
907 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
908 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
909 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
910 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
911 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
912 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
913 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
914 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
915 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
916 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
917 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
918 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
919 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
920 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
921 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
922 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
923 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
924 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
925 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
926 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
927 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
928 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
929 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
930 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
931 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
932 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
933 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
934 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
935 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
936 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
937 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
938 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
939 7:57:37 PM ecuExplorer.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
940 7:57:37 PM ecuExplorer
Sun Aug 05, 2007 4:11 pm
by radsdau
Looks like a 'hello' message (3 bytes), reading the 3 bytes from the loop-back (i.e., reading the bytes you just wrote out), then waiting for a response from the ECU, which is apparently not coming. The reads with length = 0 are polling for incoming bytes.
Sun Aug 05, 2007 7:22 pm
by 03scoobysnack
ok that makes some sense so do you think the ecu could be locked up or possibly a wiring issue. I was able to read the ecu the first time and i saved the stock map. Then i attemptd to write my new xpt stg2 map and i got the low voltage and then jumped the 12v to the flash block connector and got the denso02 boot load message, unable to read kernel, etc.
SO, with all that said i would be led to believe the ecu is locked somehow not allowing me to communicate with it because i shorted it out... idk just a theory..
Anyone have any other comments they are much appreciated i am desperate to find a solution.
Cheers,
Jordan
Tue Aug 07, 2007 4:15 pm
by radsdau
If the car still starts, you still have hope. It should be safe enough to put 12.0V on the flash voltage pin. Double check all your other connections, USB drivers, etc. Can you talk to it with ECUExplorer?
Tue Aug 07, 2007 8:58 pm
by 03scoobysnack
yea i have all of that done but i still get the denso02 boot load message unable to load kernel ever since i jumped the 12v. thats why i think it is in a safemode or something.
I can access it via ecuexplorer and data log with it runnning and when the diagnostic connecctors are all pluged in the service engine light blinks adn the fans cycle on and off.
That is why i think it has to be an ecu problem.
what do you think?
Wed Aug 08, 2007 5:24 pm
by radsdau
If all that is happening, the ECU is programmed and running. It could be a dead OpenPort device... perhaps the 12V smoked something inside that? Other than that there are only a few connections between OpenPort and ECU so use a meter to check all those.
Thu Aug 09, 2007 9:38 am
by 03scoobysnack
I think i need to clarify. The problem is i can not read or write on the ecu. I can enter diagnoxtic mode with the blinkn engine light and the fans cycling, but the fans should stop cycling once i am reading or writing(after i hit the ok button and turn the key).
Also i can monitor the vechiles sensors through ecu explorer so i know there i s no hardware or software issue because i have this ability. The Ecu must be in a safemode. I have had a few other people look at it who do a considerable amount of tuning and i was told i need to contact cboles. He apparently will falsh your ecu if you send it to him, idk i have sent him and await his reply.
although i do agree about the 12v maybe frying something but it would have to be the ecu switching to a safemode as i was able to access it and read the stock map prior to the 12v jump.
Sun Aug 12, 2007 6:10 am
by 03scoobysnack
Since im almost 100% positive that the ecu is locked and i cannnot read or write to it, should i just buy a new ecu or uswed ecu or try to get clobes to do it. he didnt reply to my email so i think ill be buying and ecu...
Sun Aug 12, 2007 9:15 am
by cboles
I have sent you a seperate email. If you can send the ECU in, I'll be happy to take a look and see what can be done.
Tue Jan 22, 2008 12:40 pm
by iveytune
Make sure your engine grounds are hooked up properly.
Sean
