Question about ECUflash
Postby rogerh » Fri Jul 06, 2007 4:20 pm
I hope I posted this in the right forum.
I'll try and be as descriptive as possible....
I would like to upload my stock ROM file for an USDM 05 Evo 8 MR so ppl have access to it if they need it.
I downloaded ECUflash 1.30
Installed / set up
I have my Tactrix cable connected to the laptop and to the car.
Upon opening ECUflash for the first time, I received a FTchipID.dll error and my Read from ECU, Write to ECU, Test Write to ECU and Compare to ECU icons are not functional
Did the following: Copied the FTChipID.dll file from my C:\Program Files\OpenECU\EcuFlash\drivers\x86 to C:\Windows\system32
The error seems to be eliminated.
However, my Read from ECU, Write to ECU, Test Write to ECU and Compare to ECU icons are STILL not functional.
Any insight on what the problem could be would be very appreciated.
rogerh
Postby salex » Fri Jul 06, 2007 11:46 pm
Try reinstalling the FTDI drivers. You should be able to find them in your \openecu\ecuflash folder.
Once you have reinstalled them, connect your cable and go through the hardware installation guide.
Launch ecuflash with your openport cable connected and you should be able to see its id on the bottom right part of the screen.
salex
Postby rogerh » Fri Jul 13, 2007 10:13 pm
Worked like a charm.
You help is much appreciated!
Thank you.
rogerh
