Problems with ecuflash w/pics
PostPosted: Sun Apr 22, 2007 7:30 pm
by ace79603
hey guys I'm haveing troubles with ecu flash when I click on it I get the problem shown in the pic.
It was working fine. I was looking at an evo rom and my eclipse rom and messing with them then I X'd out ant clicked don't save and when I tried again I got this
any help will be appreciated thanks
I already tried uninstlling it and reinstalling it and it didn't work
PostPosted: Mon Apr 23, 2007 3:47 pm
by radsdau
Looks like an XML compatibility problem to me. I think Colby said he was going to provide a bit more info on the nature of these errors in later versions.
I suspect you're somehow using old XMLs with the new ECUFlash. Check the MetaData directory setting.
PostPosted: Tue Apr 24, 2007 3:28 pm
by cboles
In general, the problem seems to be with corrupt XML files, as there have been no real "version changes" in these. Try reinstalling the software, or making sure that you have EcuFlash pointed to the correct rommetadata directory in the options.
PostPosted: Wed Apr 25, 2007 1:03 pm
by C6ect.ect
And do not touch the color (colour) display properties or else it will very likely occur again
PostPosted: Wed Apr 25, 2007 11:16 pm
by ace79603
ok thanks guys
I did mess with the colors so that might have caused it
I deleted all my subaru stuff (everything not mits)
nd all I have to do is press enter 3 times now and after that everything works fine
I had already tried uninstalling it and installing it again and it didn't work so I guess I will live with it thanks guys
