Hi,
This is probably the correct forum part..
Background:
I am trying to read the ECU on my Euro EVO 9 2006.
I am using a PC with win xp, a tactrix cable and ecuflash 1.3.
I get these errors when trying to read the ecu on my EVO 9 after I have connected the usb-cable, turned on the ignition, selected "read from ecu" and selected 2006 evo9/at in the list and pressed OK.
[23:27:37.140] 121 ROM metadata models read.
[23:27:37.140] checksum module "subarudbw" loaded.
[23:27:37.140] flashing tool "wrx02" loaded.
[23:27:37.140] flashing tool "wrx04" loaded.
[23:27:37.140] flashing tool "sti04" loaded.
[23:27:37.140] flashing tool "sti05" loaded.
[23:27:37.140] flashing tool "mitsukernel" loaded.
[23:27:37.140] flashing tool "mitsukernelocp" loaded.
[23:27:37.140] flashing tool "mitsubootloader" loaded.
[23:27:49.531] unable to connect to vehicle interface.
I have tried to downgrade to ecuflash 1.28 but it gives an other error, it says something like "sending init 1, sending init 2, sending init 3" then it gives a popup like "error, check the log"
Cable seems to work as far as i can see.
Please help, I am getting more and more frustrated..
The ECU is supposed to be stock. I had problems running EVOscan also, mitsulogger does work though..
Thanks..
