ECUFlash - XML Handler Helper errors
Postby TouringBubble » Mon Apr 02, 2007 4:46 am
I've tried several fresh installs to try to alleviate the problem, but it keeps returning. This is what happens:
I install ECUFlash
I load it the first time and all is well
I open a ROM and make some edits
Save the ROM and close ECUFlash
Open ECUFlash again and get LOTS of these error messages:
"Parse error at line 123, column 304: unexpected character" (also on line 187)
After holding down enter for a while I can finally get to ECUFlash and it seems to work fine.
This is my task info when I finally get to the app:
[10:39:31.234] Version 1.30.1095
[10:39:31.234] 8 memory models read.
[10:43:31.359] Unable to find parent metadata sti04base
[10:43:31.359] ROM metadata models A2ZJ201D.xml is invalid.
[10:43:32.218] Unable to find parent metadata sti04base
[10:43:32.218] ROM metadata models A2ZJ500F.xml is invalid.
[10:43:32.703] Unable to find parent metadata sti04base
[10:43:32.718] ROM metadata models A2ZJ500I.xml is invalid.
[10:43:32.750] Unable to find parent metadata sti04base
[10:43:32.750] ROM metadata models A2ZJ500M.xml is invalid.
[10:43:32.796] Unable to find parent metadata sti05base
[10:43:32.796] ROM metadata models A8DH100I.xml is invalid.
[10:43:32.843] Unable to find parent metadata sti05base
[10:43:32.843] ROM metadata models A2WC500L.xml is invalid.
[10:43:32.875] Unable to find parent metadata sti05base
[10:43:32.875] ROM metadata models A2WC500N.xml is invalid.
[10:43:32.921] Unable to find parent metadata sti05base
[10:43:32.921] ROM metadata models A2WC501L.xml is invalid.
[10:43:32.953] Unable to find parent metadata sti05base
[10:43:32.953] ROM metadata models A2WC510C.xml is invalid.
[10:43:33.015] Unable to find parent metadata sti05base
[10:43:33.015] ROM metadata models A2WC510N.xml is invalid.
[10:43:33.046] Unable to find parent metadata sti05base
[10:43:33.046] ROM metadata models A2WC521C.xml is invalid.
[10:43:33.078] Unable to find parent metadata sti05base
[10:43:33.078] ROM metadata models A2WC521N.xml is invalid.
[10:43:33.140] Unable to find parent metadata sti05base
[10:43:33.140] ROM metadata models A2WC522N.xml is invalid.
[10:43:33.171] Unable to find parent metadata sti05base
[10:43:33.171] ROM metadata models A2WF200N.xml is invalid.
[10:43:33.218] Unable to find parent metadata sti04base
[10:43:33.218] ROM metadata models A2ZJ800G.xml is invalid.
[10:43:33.250] Unable to find parent metadata sti04base
[10:43:33.250] ROM metadata models A2ZJ500J.xml is invalid.
[10:43:33.281] Unable to find parent metadata sti04base
[10:43:33.281] ROM metadata models A2ZJ700J.xml is invalid.
[10:43:33.343] Unable to find parent metadata sti04base
[10:43:33.343] ROM metadata models A2ZJ710J.xml is invalid.
[10:43:33.375] Unable to find parent metadata sti05base
[10:43:33.375] ROM metadata models A2ZJB10J.xml is invalid.
[10:43:33.437] Unable to find parent metadata sti05base
[10:43:33.437] ROM metadata models A2ZJB11J.xml is invalid.
[10:43:33.468] Unable to find parent metadata sti05base
[10:43:33.468] ROM metadata models A2ZJE11J.xml is invalid.
[10:43:33.515] Unable to find parent metadata sti05base
[10:43:33.515] ROM metadata models A8DH200V.xml is invalid.
[10:43:33.546] Unable to find parent metadata sti05base
[10:43:33.546] ROM metadata models A8DH200Z.xml is invalid.
[10:43:33.578] ROM metadata models sti04base.xml is invalid.
[10:43:33.609] ROM metadata models sti05base.xml is invalid.
[10:43:33.671] Unable to find parent metadata wrxbase
[10:43:33.671] Unable to find parent metadata A4RG060Q
[10:43:33.671] ROM metadata models A4RG010Q.xml is invalid.
[10:43:33.718] Unable to find parent metadata wrxbase
[10:43:33.718] Unable to find parent metadata A4RG060Q
[10:43:33.718] ROM metadata models A4RG0200.xml is invalid.
[10:43:33.765] Unable to find parent metadata wrxbase
[10:43:33.765] Unable to find parent metadata A4RG052N
[10:43:33.765] ROM metadata models A4RG0500.xml is invalid.
[10:43:33.812] Unable to find parent metadata wrxbase
[10:43:33.812] Unable to find parent metadata A4RG052N
[10:43:33.812] ROM metadata models A4RG050N.xml is invalid.
[10:43:33.875] Unable to find parent metadata wrxbase
[10:43:33.875] Unable to find parent metadata A4RG052N
[10:43:33.875] ROM metadata models A4RG050R.xml is invalid.
[10:43:33.906] Unable to find parent metadata wrxbase
[10:43:33.906] Unable to find parent metadata A4RG052N
[10:43:33.906] ROM metadata models A4RG051N.xml is invalid.
[10:43:33.937] Unable to find parent metadata wrxbase
[10:43:33.937] ROM metadata models A4RG052N.xml is invalid.
[10:43:34.000] Unable to find parent metadata wrxbase
[10:43:34.000] Unable to find parent metadata A4RG060Q
[10:43:34.000] ROM metadata models A4RG060P.xml is invalid.
[10:43:34.046] Unable to find parent metadata wrxbase
[10:43:34.046] ROM metadata models A4RG060Q.xml is invalid.
[10:43:34.109] Unable to find parent metadata wrxbase
[10:43:34.109] Unable to find parent metadata A4RM100H
[10:43:34.109] ROM metadata models A4RM000H.xml is invalid.
[10:43:34.156] Unable to find parent metadata wrxbase
[10:43:34.156] Unable to find parent metadata A4RM100H
[10:43:34.156] ROM metadata models A4RM100G.xml is invalid.
[10:43:34.203] Unable to find parent metadata wrxbase
[10:43:34.203] ROM metadata models A4RM100H.xml is invalid.
[10:43:34.234] Unable to find parent metadata wrxbase
[10:43:34.234] ROM metadata models A4RM200K.xml is invalid.
[10:43:34.281] Unable to find parent metadata wrxbase
[10:43:34.281] Unable to find parent metadata A4RN200H
[10:43:34.281] ROM metadata models A4RN1000.xml is invalid.
[10:43:34.343] Unable to find parent metadata wrxbase
[10:43:34.343] Unable to find parent metadata A4RN200H
[10:43:34.343] ROM metadata models A4RN100Q.xml is invalid.
[10:43:34.406] Unable to find parent metadata wrxbase
[10:43:34.406] ROM metadata models A4RN200H.xml is invalid.
[10:43:34.437] Unable to find parent metadata wrxbase
[10:43:34.437] ROM metadata models A4RN300G.xml is invalid.
[10:43:34.484] Unable to find parent metadata wrxbase
[10:43:34.484] Unable to find parent metadata A4RN300G
[10:43:34.484] ROM metadata models A4RN300I.xml is invalid.
[10:43:34.531] Unable to find parent metadata wrxbase
[10:43:34.531] Unable to find parent metadata A4SD900A
[10:43:34.531] ROM metadata models A4SD800A.xml is invalid.
[10:43:34.578] Unable to find parent metadata wrxbase
[10:43:34.578] Unable to find parent metadata A4SD900A
[10:43:34.578] Unable to find parent metadata A4SD900B
[10:43:34.578] ROM metadata models A4SD800B.xml is invalid.
[10:43:34.640] Unable to find parent metadata wrxbase
[10:43:34.640] ROM metadata models A4SD900A.xml is invalid.
[10:43:34.671] Unable to find parent metadata wrxbase
[10:43:34.671] Unable to find parent metadata A4SD900A
[10:43:34.671] ROM metadata models A4SD900B.xml is invalid.
[10:43:34.703] Unable to find parent metadata wrxbase
[10:43:34.703] Unable to find parent metadata A4SDA01Q
[10:43:34.703] ROM metadata models A4SDA00P.xml is invalid.
[10:43:34.765] Unable to find parent metadata wrxbase
[10:43:34.765] Unable to find parent metadata A4SDA01Q
[10:43:34.765] ROM metadata models A4SDA00Q.xml is invalid.
[10:43:34.796] Unable to find parent metadata wrxbase
[10:43:34.796] Unable to find parent metadata A4SDA01Q
[10:43:34.796] ROM metadata models A4SDA01B.xml is invalid.
[10:43:34.843] Unable to find parent metadata wrxbase
[10:43:34.843] ROM metadata models A4SDA01Q.xml is invalid.
[10:43:34.875] Unable to find parent metadata wrxbase
[10:43:34.875] ROM metadata models A4SE700D.xml is invalid.
[10:43:34.937] Unable to find parent metadata wrxbase
[10:43:34.937] Unable to find parent metadata A4SE700D
[10:43:34.937] ROM metadata models A4SE700E.xml is invalid.
[10:43:34.968] Unable to find parent metadata wrxbase
[10:43:34.984] Unable to find parent metadata A4SE700D
[10:43:34.984] ROM metadata models A4SE700I.xml is invalid.
[10:43:35.031] Unable to find parent metadata wrxbase
[10:43:35.031] ROM metadata models A4SE900D.xml is invalid.
[10:43:35.078] Unable to find parent metadata wrxbase
[10:43:35.078] Unable to find parent metadata A4SE900D
[10:43:35.078] ROM metadata models A4SE900I.xml is invalid.
[10:43:35.109] Unable to find parent metadata wrxbase
[10:43:35.109] ROM metadata models A4SG900C.xml is invalid.
[10:43:35.140] Unable to find parent metadata wrxbase
[10:43:35.140] ROM metadata models A4SGA00C.xml is invalid.
[10:43:35.171] Unable to find parent metadata wrxbase
[10:43:35.171] ROM metadata models A4SGC00C.xml is invalid.
[10:43:35.234] Unable to find parent metadata wrxbase
[10:43:35.234] ROM metadata models A4SGD10C.xml is invalid.
[10:43:35.265] Unable to find parent metadata wrxbase
[10:43:35.265] Unable to find parent metadata A4SGD10C
[10:43:35.265] ROM metadata models A4SGE00C.xml is invalid.
[10:43:35.328] Unable to find parent metadata wrxbase
[10:43:35.328] Unable to find parent metadata A4SGD10C
[10:43:35.328] ROM metadata models A4SGE01C.xml is invalid.
[10:43:35.375] Unable to find parent metadata wrxbase
[10:43:35.375] Unable to find parent metadata A4TC101L
[10:43:35.375] ROM metadata models A4TC101K.xml is invalid.
[10:43:35.406] Unable to find parent metadata wrxbase
[10:43:35.406] ROM metadata models A4TC101L.xml is invalid.
[10:43:35.468] Unable to find parent metadata wrxbase
[10:43:35.468] Unable to find parent metadata A4TC300L
[10:43:35.468] ROM metadata models A4TC300K.xml is invalid.
[10:43:35.500] Unable to find parent metadata wrxbase
[10:43:35.500] ROM metadata models A4TC300L.xml is invalid.
[10:43:35.531] Unable to find parent metadata wrxbase
[10:43:35.531] Unable to find parent metadata A4TC300L
[10:43:35.531] ROM metadata models A4TC400K.xml is invalid.
[10:43:35.578] Unable to find parent metadata wrxbase
[10:43:35.578] Unable to find parent metadata A4TC300L
[10:43:35.578] ROM metadata models A4TC400L.xml is invalid.
[10:43:35.625] Unable to find parent metadata wrxbase
[10:43:35.625] Unable to find parent metadata A4TC300L
[10:43:35.625] ROM metadata models A4TC401K.xml is invalid.
[10:43:35.687] Unable to find parent metadata wrxbase
[10:43:35.687] Unable to find parent metadata A4TC300L
[10:43:35.687] ROM metadata models A4TC401L.xml is invalid.
[10:43:35.734] Unable to find parent metadata wrxbase
[10:43:35.734] ROM metadata models A4TE000A.xml is invalid.
[10:43:35.765] Unable to find parent metadata wrxbase
[10:43:35.765] Unable to find parent metadata A4TE001G
[10:43:35.765] ROM metadata models A4TE000G.xml is invalid.
[10:43:35.828] Unable to find parent metadata wrxbase
[10:43:35.828] Unable to find parent metadata A4TE002B
[10:43:35.828] ROM metadata models A4TE001B.xml is invalid.
[10:43:35.875] Unable to find parent metadata wrxbase
[10:43:35.875] Unable to find parent metadata A4TE002B
[10:43:35.875] ROM metadata models A4TE001C.xml is invalid.
[10:43:35.906] Unable to find parent metadata wrxbase
[10:43:35.906] ROM metadata models A4TE001G.xml is invalid.
[10:43:35.968] Unable to find parent metadata wrxbase
[10:43:35.968] ROM metadata models A4TE001I.xml is invalid.
[10:43:36.000] Unable to find parent metadata wrxbase
[10:43:36.000] ROM metadata models A4TE002B.xml is invalid.
[10:43:36.031] Unable to find parent metadata wrxbase
[10:43:36.031] Unable to find parent metadata A4TE002B
[10:43:36.031] ROM metadata models A4TE002C.xml is invalid.
[10:43:36.093] Unable to find parent metadata wrxbase
[10:43:36.093] Unable to find parent metadata A4TE001G
[10:43:36.093] ROM metadata models A4TE100G.xml is invalid.
[10:43:36.140] Unable to find parent metadata wrxbase
[10:43:36.140] Unable to find parent metadata A4TE000A
[10:43:36.140] ROM metadata models A4TE200A.xml is invalid.
[10:43:36.171] Unable to find parent metadata wrxbase
[10:43:36.171] ROM metadata models A4TE300D.xml is invalid.
[10:43:36.203] Unable to find parent metadata WRXBASE
[10:43:36.203] ROM metadata models A4TF300E.xml is invalid.
[10:43:36.265] Unable to find parent metadata WRXBASE
[10:43:36.265] ROM metadata models A4TF300F.xml is invalid.
[10:43:36.296] Unable to find parent metadata wrxbase
[10:43:36.296] ROM metadata models A4TF400E.xml is invalid.
[10:43:36.328] Unable to find parent metadata wrxbase
[10:43:36.328] Unable to find parent metadata A4TF400E
[10:43:36.328] ROM metadata models A4TF400F.xml is invalid.
[10:43:36.390] Unable to find parent metadata wrxbase
[10:43:36.390] Unable to find parent metadata A4TF400E
[10:43:36.390] ROM metadata models A4TF500E.xml is invalid.
[10:43:36.437] Unable to find parent metadata wrxbase
[10:43:36.437] Unable to find parent metadata A4TF400E
[10:43:36.437] ROM metadata models A4TF500F.xml is invalid.
[10:43:36.500] Unable to find parent metadata WRXBASE
[10:43:36.500] ROM metadata models A4TF510E.xml is invalid.
[10:43:36.531] Unable to find parent metadata WRXBASE
[10:43:36.531] Unable to find parent metadata A4TF510E
[10:43:36.531] ROM metadata models A4TF510F.xml is invalid.
[10:43:36.562] Unable to find parent metadata wrxbase
[10:43:36.562] Unable to find parent metadata A4TF520F
[10:43:36.562] ROM metadata models A4TF520E.xml is invalid.
[10:43:36.625] Unable to find parent metadata wrxbase
[10:43:36.625] ROM metadata models A4TF520F.xml is invalid.
[10:43:36.656] Unable to find parent metadata wrxbase
[10:43:36.656] ROM metadata models A4TF800E.xml is invalid.
[10:43:36.703] Unable to find parent metadata wrxbase
[10:43:36.703] ROM metadata models A4TF800F.xml is invalid.
[10:43:36.734] Unable to find parent metadata wrxbase
[10:43:36.734] Unable to find parent metadata A4TH100H
[10:43:36.734] ROM metadata models A4TH000O.xml is invalid.
[10:43:36.765] Unable to find parent metadata wrxbase
[10:43:36.765] ROM metadata models A4TH100H.xml is invalid.
[10:43:36.828] Unable to find parent metadata wrxbase
[10:43:36.828] Unable to find parent metadata A4TJ121C
[10:43:36.828] ROM metadata models A4TJ111B.xml is invalid.
[10:43:36.859] Unable to find parent metadata wrxbase
[10:43:36.859] Unable to find parent metadata A4TJ121C
[10:43:36.859] ROM metadata models A4TJ111C.xml is invalid.
[10:43:36.921] Unable to find parent metadata wrxbase
[10:43:36.937] Unable to find parent metadata A4TJ121C
[10:43:36.937] ROM metadata models A4TJ121B.xml is invalid.
[10:43:36.968] Unable to find parent metadata wrxbase
[10:43:36.968] ROM metadata models A4TJ121C.xml is invalid.
[10:43:37.031] Unable to find parent metadata sti05base
[10:43:37.031] ROM metadata models A8DH200X.xml is invalid.
[10:43:37.078] Unable to find parent metadata sti05base
[10:43:37.078] ROM metadata models A8DH201X.xml is invalid.
[10:43:37.093] ROM metadata models wrxbase.xml is invalid.
[10:43:37.109] 42 ROM metadata models read.
[10:43:37.109] checksum module "subarudbw" loaded.
[10:43:37.109] flashing tool "wrx02" loaded.
[10:43:37.109] flashing tool "wrx04" loaded.
[10:43:37.109] flashing tool "sti04" loaded.
[10:43:37.109] flashing tool "sti05" loaded.
[10:43:37.109] flashing tool "mitsukernel" loaded.
[10:43:37.109] flashing tool "mitsukernelocp" loaded.
[10:43:37.109] flashing tool "mitsubootloader" loaded.
[10:43:37.109] error loading FTChipID.DLL
I get this on 2 different machines. Can anyone help?
I think it's very strange because it seems like the errors are coming from the Subaru definition files but I've only edited Mitsu ROMs. I did attempt to add the 2byte load values to the Evo9 definition file, but I've since completely uninstalled the app and removed all definition files.
Thanks for any help you can provide.
TouringBubble
Postby AutoXer » Sat May 12, 2007 2:58 pm
I get the same error. Anybody have a fix?
AutoXer
