06 STI: First time read wont work!! HELP
Postby derekok » Thu Mar 01, 2007 8:00 am
I selected the DBW 05-06 sti option and once the pop up came to turn ignition on I did and almost instantly pressed OK.
Here is what I get:
[19:11:46.796] ssm2_init
[19:11:47.171] kernel get version
[19:11:47.687] validating denso kernel ram area addr: FFFF3000 len: 0008
[19:12:12.140] ssm2_init
[19:12:12.281] ECU ID is 43 12 59 40 06
[19:12:12.296] ssm2_cmd_0x81
[19:12:12.328] ssm2_cmd_0x83
[19:12:12.390] denso challenge-response
[19:12:12.437] challenge is C6 B7 8E F5
[19:12:12.437] response is 00 29 07 94
[19:12:12.484] ssm2_cmd_0x10
[19:12:12.875] validating denso kernel ram area addr: FFFF3000 len: 0C28
[19:12:25.000] ssm2_init
[19:12:25.140] ECU ID is 43 12 59 40 06
[19:12:25.140] ssm2_cmd_0x81
[19:12:25.187] ssm2_cmd_0x83
[19:12:25.234] denso challenge-response
[19:12:25.281] challenge is 7B 1D F6 21
[19:12:25.296] response is 00 33 49 81
[19:12:25.343] ssm2_cmd_0x10
[19:12:25.703] validating denso kernel ram area addr: FFFF3000 len: 0C28
THIS was an effort of 3 times..
Im really frustrated. I have read some use green connectors...I have no idea where those are and if 06 sti needs it.
Derek
derekok
Re: 06 STI: First time read wont work!! HELP
Postby Jon [in CT] » Thu Mar 01, 2007 9:09 am
derekok wrote:I have read some use green connectors...I have no idea where those are and if 06 sti needs it.
It is necessary to connect the two green test mode connectors. They're under the lower dash just to the left of the steering wheel column.
