Page 1 of 2
ECUFlash - JDM ECUs
Wed Jan 11, 2006 2:16 am
by mixja
Will ECUFlash v1.01.72 allow you to read an ECU ROM image from a JDM STI Spec C ECU?
Also, is there any software around that allows you to read the ROM image and show you the various maps the ECU is using?
Wed Jan 11, 2006 3:23 am
by mixja
I attempted to read from the ECU, unfortunately it failed...
Car was set to USDM WRX 2002-2003. Using OpenPort 1.2 cable. Green test connectors were joined together.
Should the car do funny things with the test connectors attached? - the car fans kept turning on and off repeatedly in test mode...
Here's the output from ECUFlash:
[0.000] kernel flash disable
[3.115] denso02_bootloader_cmd_start
[3.074] denso02_bootloader_cmd_start
[3.004] denso02_bootloader_cmd_start
[2.975] denso02_bootloader_cmd_start
[2.974] denso02_bootloader_cmd_start
[2.293] unable to load kernel
Heres the portmon capture:
32 0.00000196 ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
33 0.00000196 ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
34 0.00330908 ecuflash.exe IOCTL_SERIAL_SET_BAUD_RATE VCP0 SUCCESS Rate: 4800
35 0.00250060 ecuflash.exe IOCTL_SERIAL_CLR_RTS VCP0 SUCCESS
36 0.00287048 ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
37 0.00297161 ecuflash.exe IOCTL_SERIAL_SET_LINE_CONTROL VCP0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
38 0.00000251 ecuflash.exe IOCTL_SERIAL_SET_CHAR VCP0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
39 0.00294227 ecuflash.exe IOCTL_SERIAL_SET_HANDFLOW VCP0 SUCCESS Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
40 0.00000223 ecuflash.exe IOCTL_SERIAL_SET_TIMEOUTS VCP0 SUCCESS RI:-1 RM:0 RC:0 WM:50 WC:0
41 0.00294898 ecuflash.exe IOCTL_SERIAL_SET_WAIT_MASK VCP0 SUCCESS Mask: CTS DSR
42 0.00000279 ecuflash.exe IRP_MJ_FLUSH_BUFFERS VCP0 SUCCESS
43 0.00294283 ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
44 0.00000419 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
45 0.00294786 ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
46 0.00000894 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
47 0.00000363 ecuflash.exe IOCTL_SERIAL_SET_QUEUE_SIZE VCP0 SUCCESS InSize: 16384 OutSize: 16384
48 0.00000223 ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
49 0.00000223 ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
50 0.00000223 ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
51 0.00000223 ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
52 0.00000196 ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
53 0.00000168 ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
54 0.00000196 ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
55 0.00000196 ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
56 0.00225029 ecuflash.exe IOCTL_SERIAL_SET_BAUD_RATE VCP0 SUCCESS Rate: 39473
57 0.00296574 ecuflash.exe IOCTL_SERIAL_CLR_RTS VCP0 SUCCESS
58 0.00297524 ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
59 0.00297049 ecuflash.exe IOCTL_SERIAL_SET_LINE_CONTROL VCP0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
60 0.00000279 ecuflash.exe IOCTL_SERIAL_SET_CHAR VCP0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
61 0.00294171 ecuflash.exe IOCTL_SERIAL_SET_HANDFLOW VCP0 SUCCESS Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
62 0.00000223 ecuflash.exe IOCTL_SERIAL_SET_TIMEOUTS VCP0 SUCCESS RI:-1 RM:0 RC:0 WM:50 WC:0
63 0.00294088 ecuflash.exe IOCTL_SERIAL_SET_WAIT_MASK VCP0 SUCCESS Mask: CTS DSR
64 0.00000307 ecuflash.exe IRP_MJ_FLUSH_BUFFERS VCP0 SUCCESS
65 0.00000335 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
66 0.00066293 ecuflash.exe IRP_MJ_WRITE VCP0 SUCCESS Length 6: BE EF 00 01 21 CF
67 0.00000615 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: BE
68 0.00000279 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: EF
69 0.00000251 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: 00
70 0.00000279 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: 01
71 0.00000279 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: 21
72 0.00000251 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: CF
73 0.00000279 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
74 0.00000419 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
75 0.00000419 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
76 0.00000447 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
77 0.00000447 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
78 0.00000447 ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
Wed Jan 11, 2006 4:52 am
by NeverLies
mixja wrote:I attempted to read from the ECU, unfortunately it failed...
This is the normal behavior when test mode is active. While Colby kernel is uploaded, fan should stop. What's your MY ? Have you been able to communicate with your car using for example ECUExplorer and your OpenPort ?
Re: ECUFlash - JDM ECUs
Wed Jan 11, 2006 5:34 am
by crazymikie
[quote="mixja"]Will ECUFlash v1.01.72 allow you to read an ECU ROM image from a JDM STI Spec C ECU?
Also, is there any software around that allows you to read the ROM image and show you the various maps the ECU is using?[/quote]
You probably need to use the older command line version. I've been unsuccessful in getting the new GUI version to work with 2002/2003 ECUs. I was able to dump a v7 JDM ECU using the 0.91 version of the command line tool.
Mike
Wed Jan 11, 2006 10:46 am
by NeverLies
I have sucessfully used the GUI version with the OpenPort 1.2 and previous version on my 2003.
With the latest GUI version, hit OK, then turn ON the ignition. It should start.
Wed Jan 11, 2006 11:17 am
by Kha0S
FWIW, the GUI version of ecuFlash works fine with my 02 USDM WRX.
Wed Jan 11, 2006 1:42 pm
by mixja
NeverLies wrote:mixja wrote:I attempted to read from the ECU, unfortunately it failed...
MY06 JDM STI Spec C Type RA. I can successfully connect with ECUExplorer no problems...
I'll try clicking OK first and then turning the ignition on, the software asks you to do it the other way round. If it still doesn't work, I'll try the cmd line version...
Wed Jan 11, 2006 1:44 pm
by Spiider
I use the "ecuflash gui v3" on my JDM ver8 STi (ecu model# AH581) without any problems.
You may need to jumper the white flash block.
Wed Jan 11, 2006 6:41 pm
by Xmicho
For me (2002 Euro WRX), it works if I click on the flash icon (dialogue box will the appear), turn the ignition on then immediately hit ok. If I do it right, the check engine light does not come on when I turn the ignition on. Works every time!
Thu Jan 12, 2006 4:30 am
by NeverLies
So your car should be a DBW and not yet supported except in monitoring mode.
Thu Jan 12, 2006 3:27 pm
by mixja
Sorry, what is "DBW"? The ECU is a Denso ECU.
Fri Jan 13, 2006 8:55 am
by FrSTi
DBW is for Drive By Wire throttle.
Your car is fitted with a new generation ECU, not yet supported...
Hang on
Fri Jan 13, 2006 6:30 pm
by Spiider
I knew the USDM's were DBW, but I thought the JDM's weren't DBW. (?) Maybe just the '06+.
Sat Jan 14, 2006 3:20 pm
by mixja
Spiider wrote:I knew the USDM's were DBW, but I thought the JDM's weren't DBW. (?) Maybe just the '06+.
Correct, my car (JDM MY06) is not DBW...does this mean it should be supported by the current version of ECUFlash?
Sun Jan 15, 2006 5:53 am
by Mo
MY 05 JDM works with the GUI so would've expected the 06 to, you have to jumper the flash block connector and be very quick when you turn on the ignition. It took a few goes but got there in the end.
Mixja, are you in the UK?
