07 STI, does it work?
Does EcuFlash work on the 07 STI? When I try to use it I get nothing, as if it's not pluged into the OBD2 plug. EcuFlash shows the cable being pluged into the USB and it says Ready in the lower left corner. When I click on the Read from ECU's flash memory icon I get the same thing whether it's pluged into the OBD2 or not. It doesn't seem to matter when or how I turn the key to ingition on.
If EcuFlash does't work on the 07 STI yet, when will it?
