reflash ralliart ecu
PostPosted: Thu Dec 14, 2006 10:59 am
by eiu
can i reflash my ralliart ecu with ecu flash? and with witch map? help me please. thanks
miltek exhaust, power maniflow, green filter and 1,45 bar
PostPosted: Thu Dec 14, 2006 1:12 pm
by Rotawerx
What model Car/ECU...?
Quite likely. I would not just flash another rom however.
I would modify the existing rom by changing the existing maps and flashing the modified rom back to ECU, and keep an original rom saved for backup.
By all means, copy maps into the rom, but advise using the original one and modifying it as opposed to a whole rom from another car.
PostPosted: Thu Dec 14, 2006 2:00 pm
by Evo4Mad
there is a slight risk in that they changed the pinout on some of the ecu's. but not very likely.. I have flashed an E8 ecu with ALL E7 and E8 available roms, and haven't done any damage to the ecu yet, although I have disconnected all the non necessary fan control and emission purge solenoids wiring though.
PostPosted: Thu Dec 14, 2006 10:38 pm
by eiu
evo 8 2005, the white ralliart ecu sport
PostPosted: Wed Dec 20, 2006 11:22 am
by eiu
can i active the antilag on my ralliart sport ecu ? because i am very interested about this!!!!
PostPosted: Mon Jan 29, 2007 2:41 am
by Sanctifier
eiu wrote:can i active the antilag on my ralliart sport ecu ? because i am very interested about this!!!!
Don't know about reflash possibilities but for Anti-lag itself... but I would think TWICE first.
If used to show-off with a "pop" and a flame-ball you can use it sometimes...
but that's NOT really Anti-lag in the true sense.
Full Anti-lag for competitive rallying puts a hell of a load on the turbo shaft.
It can break the shaft or cause other turbo damage with frequent daily use.
Turbo life has reportedly shrunk from years... down to weeks (days in one bad case.)
Search Mitsubishi Lancer Register for more details.
My $0.02ยข
PostPosted: Sat Feb 03, 2007 11:59 pm
by eiu
ok.... what set up do you use to make flamme?
PostPosted: Sun Feb 04, 2007 2:21 am
by Sanctifier
Maybe you didn't follow... I don't want Anti-lag system because it will damage my turbo.
I prefer performance to bling. I'm not wasting money just to show off for my friends.
Sanctifier wrote:...Search Mitsubishi Lancer Register for more details.
