05 US STI Flash Problems
Postby .nate » Mon Nov 06, 2006 7:12 am
I'm trying to reflash a 05 US STI... I can read the map from the ecu fine, but the problem I'm running into is when I go to write a new image, it fails with the following:
[07:37:38.856] ssm2_init
[07:37:39.087] ssm2_init
[07:37:39.307] ssm2_init
[07:37:39.527] ssm2_init
[07:37:39.758] ssm2_init
[07:37:39.978] ssm2_init
[07:37:40.198] ssm2_init
[07:37:40.429] ssm2_init
[07:37:40.649] ssm2_init
[07:37:40.869] ssm2_init
[07:37:41.290] kernel get version
[07:37:41.841] validating denso kernel ram area addr: 020000 len: 0008
Then it says error check the logs. Attached is the image I downloaded from the car. It's ID is A2ZJB11J. Am I recieving this error because I am trying to flash a rom with the ID of A4TF800F and the ID doesnt match?
TIA
shannon_05STI.bin
2005 US STI Downloaded Image
(1 MiB) Downloaded 751 times
.nate
Postby SubieGuy » Mon Nov 06, 2006 7:20 am
Isn't A4TF800F a WRX map? Wouldn't trying to flash a WRX map onto an STi naturally fail? You should probably try to find a A2ZJB11J (AJ931 8791) image to flash onto your ECU, or modify yours and reflash with that one...
SubieGuy
Postby merchgod » Mon Nov 06, 2006 8:33 am
Yeah, that's an 05 WRX map. You cannot flash this to your car! Same year, same exact model, same exact market only.
merchgod
Postby .nate » Mon Nov 06, 2006 10:36 am
Arg my mistake. I'll try again witht he proper image.
.nate
