2005 FXT 5MT "Unknown ROM Image"??
PostPosted: Sun Oct 22, 2006 1:31 pm
by RktWgn
Just tried to download my 2005 FXT 5MT ROM to see if I could do it. It said the process was successful but then brought up a "Setup ROM" window and said "Unknown ROM Image". What should I do? I just want to look at it in Enginuity (no changes for now) and then see if I can flash it back to the ECU. Am I out of luck for now?
Scott
PostPosted: Sun Oct 22, 2006 3:57 pm
by merchgod
Just choose inherit and select an 05 FXT rom (if there isn't one then choose an 05 sti). Then select 'save rom as' from the main menu. Take that file and open in Enginuity. If Enginuity gives you an error of "ecu not found", then post up your rom on the Enginuity site and we can add it.
PostPosted: Sun Oct 22, 2006 7:05 pm
by RktWgn
Worked like a charm. And my ROM revision is the one Enginuity has already set up for the '05 FXT. Lucky me! Thanks for the quick response.
