ECUFlash unable to pull roms of JDM 03 STI's
Postby west_minist » Sun Aug 13, 2006 2:02 pm
Hello Colb and others!
I have a friend in my part of the world that is unable to pull roms off 2 JDM 03 STI's.
He himself have a 03 STI swapped in his wrx and can pull it.
Now both cars have never been ecutek [so the owners state]. One of them is very lively. That on feels very good with a very happy IAM = 16 and pulling nice w/ still mods, which is not normal for their gas.
Is there something that he can do to see what the problem is?
He states that ah581 5122 comes up in DD, but he is not sure if the revisions are the same.
JDM Twin Scroll STI 03 - ah581 5122 - A4TE002B
Postby Tuned by LIM » Thu Aug 17, 2006 10:34 am
I had same problem on same model
log file show
[18:27:53.984] Version 1.28.716
[18:27:54.004] 8 memory models read.
[18:27:54.585] 72 ROM metadata models read.
[18:27:54.585] checksum module "subarudbw" loaded.
[18:27:54.585] flashing tool "wrx02" loaded.
[18:27:54.585] flashing tool "wrx04" loaded.
[18:27:54.585] flashing tool "sti04" loaded.
[18:27:54.585] flashing tool "sti05" loaded.
[18:27:54.585] flashing tool "mitsukernel" loaded.
[18:27:54.585] flashing tool "mitsukernelocp" loaded.
[18:27:54.585] flashing tool "mitsubootloader" loaded.
[18:30:45.741] denso02_bootloader_cmd_start
[18:30:47.353] denso02_bootloader_cmd_start
[18:30:48.565] denso02_bootloader_cmd_start
[18:30:49.777] denso02_bootloader_cmd_start
[18:30:50.989] denso02_bootloader_cmd_start
[18:30:51.439] kernel get version
and get error message
second time I change flash to method others model
[18:32:31.273] Version 1.28.716
[18:32:31.293] 8 memory models read.
[18:32:31.844] 72 ROM metadata models read.
[18:32:31.844] checksum module "subarudbw" loaded.
[18:32:31.844] flashing tool "wrx02" loaded.
[18:32:31.844] flashing tool "wrx04" loaded.
[18:32:31.844] flashing tool "sti04" loaded.
[18:32:31.844] flashing tool "sti05" loaded.
[18:32:31.844] flashing tool "mitsukernel" loaded.
[18:32:31.844] flashing tool "mitsukernelocp" loaded.
[18:32:31.844] flashing tool "mitsubootloader" loaded.
[18:33:06.173] ssm2_init
[18:33:06.343] ECU ID is 2E 04 49 60 05
[18:33:06.343] ssm2_cmd_0x81
get error message
I try every method model and got error message same above.
By the way I try ECUexplorer and it's works.
A4TE002B, AH581 2003 Subaru Impeza STi twin scroll
but I never flash to this car yet.
ECU Flash and ECU Edit can't open this Rom file because I havn't no XML definition but Enginuity 0.3.2b can
Tuned by LIM
Postby west_minist » Thu Aug 17, 2006 10:35 am
I understand for this particular model, you have to push in the clutch.
Postby epifan » Thu Aug 17, 2006 11:23 am
Tuned by LIM wrote:ECU Flash and ECU Edit can't open this Rom file because I havn't no XML definition but Enginuity 0.3.2b can
You can use XMLWrite to generate description or convert enginuity XML descriptin to ecuEdit format using ecuEdit (new version can do this).
epifan
Postby cboles » Thu Aug 17, 2006 11:40 am
are you saying that you got it to read in ecuflash by pushing the clutch in?
west_minist wrote:I understand for this particular model, you have to push in the clutch.
Postby west_minist » Thu Aug 17, 2006 11:49 am
I was told this from my collegue.
I find it surprising, but then again, you have to push the clutch in to start the car.
Postby cboles » Thu Aug 17, 2006 2:15 pm
Let me know if it works!
Postby west_minist » Thu Aug 17, 2006 2:22 pm
If you mean me, it does. I was really surprise.
Postby NeverLies » Fri Aug 18, 2006 1:09 am
I think we will need to dissasemble a JDM ecu (at least this one). I hope to find some good information inside :D (Clutch sensor may control some nice feature !)
Postby west_minist » Fri Aug 18, 2006 4:13 am
Do you not have that feature in the export models?
It came out in 2001 for the bugeye. I'm not sure for previous years.
Postby FrSTi » Fri Aug 18, 2006 4:23 am
west_minist wrote:Do you not have that feature in the export models?
On EDM versions from 2001 to 2005, we don't for sure.
I don't know if we even have a clutch switch or sensor... I'll take a look.
FrSTi
Postby Tuned by LIM » Fri Aug 18, 2006 10:57 am
next time I'll try to push in the clutch.
yes, but I'm noob here really don't know about this
please introduce me how to learn this from?
sorry for my English :oops:
Tuned by LIM
Postby mixja » Tue Aug 22, 2006 6:44 pm
Make sure you have the test connector and flash block jumpered.
Select 2001-2003 WRX from the ECUFlash menu.
Turn on the ignition and then very quickly press the Read button in ECUFlash - doing this quickly is the key to success.
And you don't need to push in the clutch :lol:
mixja
Postby FrSTi » Wed Aug 23, 2006 1:03 am
I just had a look under my dash : there is no clutch switch there (neither under the bonnet ), but interstingly, I noticed there is provision to install one, exactly similar to the brake switch set up.
FrSTi
Postby west_minist » Wed Aug 23, 2006 2:20 am
Ok. Its a safety thing.
