Problem reading from 05 USDM STI
Postby timv » Sat Jul 29, 2006 6:24 pm
Hi All,
I've tried unsuccessfully to dump the ROM from my 05 USDM STI. Can someone give me some help? Here are the details:
Car: 05 USDM WRX STI
EcuFlash: 1.28.716
Cable: OpenPort 1.2
WindowsXP: Com4 <-- OpenPort
Here is the log generated as I tried to read the ROM:
[00:12:53.712] Version 1.28.716
[00:12:53.742] 8 memory models read.
[00:12:55.034] 71 ROM metadata models read.
[00:12:55.034] checksum module "subarudbw" loaded.
[00:12:55.034] flashing tool "wrx02" loaded.
[00:12:55.034] flashing tool "wrx04" loaded.
[00:12:55.034] flashing tool "sti04" loaded.
[00:12:55.034] flashing tool "sti05" loaded.
[00:12:55.034] flashing tool "mitsukernel" loaded.
[00:12:55.034] flashing tool "mitsukernelocp" loaded.
[00:12:55.034] flashing tool "mitsubootloader" loaded.
[00:12:55.034] error loading FTD2XX.DLL
[00:13:08.533] ssm2_init
[00:13:08.684] ECU ID is 3D 12 59 40 06
[00:13:08.684] ssm2_cmd_0x81
[00:13:08.744] ssm2_cmd_0x83
[00:13:08.804] denso challenge-response
[00:13:08.864] challenge is 57 96 9C 5E
[00:13:08.864] response is 00 69 3C B0
[00:13:08.924] ssm2_cmd_0x10
[00:13:09.314] validating denso kernel ram area addr: FFFF3000 len: 0C28
<<At this point an error message pops up and says to look at the logs>>
I noticed the FTDXX.DLL error so I copied that file to EcuFlash directory and tried again... here's the log:
[00:36:38.621] Version 1.28.716
[00:36:38.651] 8 memory models read.
[00:36:39.903] 71 ROM metadata models read.
[00:36:39.903] checksum module "subarudbw" loaded.
[00:36:39.903] flashing tool "wrx02" loaded.
[00:36:39.903] flashing tool "wrx04" loaded.
[00:36:39.903] flashing tool "sti04" loaded.
[00:36:39.903] flashing tool "sti05" loaded.
[00:36:39.903] flashing tool "mitsukernel" loaded.
[00:36:39.903] flashing tool "mitsukernelocp" loaded.
[00:36:39.903] flashing tool "mitsubootloader" loaded.
[00:37:12.640] ssm2_init
[00:37:12.790] ECU ID is 3D 12 59 40 06
[00:37:12.790] ssm2_cmd_0x81
[00:37:12.840] ssm2_cmd_0x83
[00:37:12.890] denso challenge-response
[00:37:12.950] challenge is CB 5D E2 B2
[00:37:12.960] response is 00 8C 53 B0
[00:37:13.030] ssm2_cmd_0x10
[00:37:13.411] validating denso kernel ram area addr: FFFF3000 len: 0C28
<<Again, got error message saying check log>>
I've tried using the EcuExplorer program and it logs/works just fine -- also reports that the ECU has serial of AJ930-8791.
I've did a search on people having trouble reading and seems that it may be a timing issue on my part (hitting OK and Turning to ON) but I have my doubts as it seems to be communicating (ie.. Challenge/Response).
I've tried several times but got the same message each time. I'll try it again and see how it goes..
Has anyone else had this sort of problem?
Thanks for your help!
-tv
timv
Postby UpPweez » Mon Jul 31, 2006 3:47 am
Did you plug in the green connectors under the dash?
UpPweez
Postby timv » Mon Jul 31, 2006 5:31 am
UpPweez wrote:Did you plug in the green connectors under the dash?
That was it! Thanks.. I should have followed the dialog box, but I must have mis-read that the green connector is for WRX (not Sti). Anyway, I was able to read the ROM out of the ecu. Thanks a bunch! :)
-tv
timv
