ecuflash trouble?
ecuflash trouble?
Postby skanitz1 » Thu Jul 17, 2008 2:50 pm
I have a 02 wrx and I am having trouble reading the ecu, this is what I get...
[19:00:04.281] Version 1.35.1650
[19:00:04.296] 11 memory models read.
[19:00:04.296] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[19:00:04.562] 250 ROM metadata models scanned.
[19:00:04.562] checksum module "subarudbw" loaded.
[19:00:04.562] flashing tool "wrx02" loaded.
[19:00:04.562] flashing tool "wrx04" loaded.
[19:00:04.562] flashing tool "sti04" loaded.
[19:00:04.562] flashing tool "sti05" loaded.
[19:00:04.562] flashing tool "mitsukernel" loaded.
[19:00:04.562] flashing tool "mitsukernelocp" loaded.
[19:00:04.562] flashing tool "shbootmode" loaded.
[19:00:13.203] Using interface OpenPort 1.3 Subaru TX48Jk392e8974d51098b6353e61c21dec2f4c501f0b3447
[19:00:29.750] denso02_bootloader_cmd_start
[19:00:30.046] readback fail
[19:00:30.953] denso02_bootloader_cmd_start
[19:00:31.250] readback fail
[19:00:32.156] denso02_bootloader_cmd_start
[19:00:32.453] readback fail
[19:00:33.359] denso02_bootloader_cmd_start
[19:00:33.656] readback fail
[19:00:34.562] denso02_bootloader_cmd_start
[19:00:34.859] readback fail
[19:00:34.984] kernel get version
[19:00:35.187] readback fail
[19:00:35.312] interface close
[19:00:35.328] interface close
the engine is currently out of the car if that makes any difference. I have the cable to the under-hood fuse box hooked up to the battery so the car has power, along with a battery charger hooked up to ensure optimal battery strength. Also the car has a dastek piggy back ecu, I don't know if this would make a difference or not? I connected the green connectors and installed the flash block... any clues to why this isnt working? Thanks.
Steve
skanitz1
Postby phijar » Thu Jul 24, 2008 11:56 am
Are you hitting OK right after turning the key to the ON position? Before the engine goes intotest mode - fans cycling and sounds like fuel pump also.
phijar
Postby skanitz1 » Thu Jul 24, 2008 3:31 pm
Yeah I'm hitting it right when I turn the key on... I don't have the engine in the car(no compression in two cylinders) or any of the fans, sesnors, etc hooked up though. I just have the battery hooked up, I did notice the fuel pump is not cycling the way I have it now so I am wondering that if the car were put together it would make a difference? ( I haven't noticed any blown fuses). I emailed Tactrix and they said it may have something to do with the piggyback ecu too... I think I may just wait till I get a motor back in it, then get it dyno-tuned without the piggy back because I am thinking of getting a 2.5 liter short block. Thanks though!
skanitz1
