ecuflash help
ecuflash help
Postby disaster999 » Tue Mar 27, 2007 4:07 am
could someone please help me get this program to work for me!!! i downloaded the program from openecu. ran it, it did its thing, installed everything, no errors no nothing, so its done..i opened the program. on the task info it gives me this "error loading FTChipID.DLL". then i noticed that at the bottom is said i have no vehicle interface. i know i installed the drivers correctly. i plugged in the cable and the computer recognizes it.
whats wrong?
disaster999
Postby disaster999 » Tue Mar 27, 2007 8:41 am
actually i got the above problem fixed, but heres a new problem
i tried to copy the rom of my euc and somehow it wont let me do it. i have cobb stage 2 installed im not sure if thats the problem.
heres the log of what happened before it gave me the error
[12:30:42.457] Version 1.30.1095
[12:30:42.457] 8 memory models read.
[12:30:43.639] 145 ROM metadata models read.
[12:30:43.639] checksum module "subarudbw" loaded.
[12:30:43.639] flashing tool "wrx02" loaded.
[12:30:43.639] flashing tool "wrx04" loaded.
[12:30:43.639] flashing tool "sti04" loaded.
[12:30:43.639] flashing tool "sti05" loaded.
[12:30:43.639] flashing tool "mitsukernel" loaded.
[12:30:43.639] flashing tool "mitsukernelocp" loaded.
[12:30:43.639] flashing tool "mitsubootloader" loaded.
[12:31:12.911] denso02_bootloader_cmd_start
[12:31:13.141] writing kernel area addr: 020000 len: 063C
[12:31:15.064] kernel get version
[12:31:15.284] reading kernel comm buffer size
[12:31:15.304] comm buffer size set to 512
[12:31:15.304] reading kernel flash buffer size
[12:31:15.324] flash buffer size set to 4096
[12:32:12.557] denso02_bootloader_cmd_start
[12:32:12.777] writing kernel area addr: 020000 len: 063C
[12:32:14.680] kernel get version
[12:32:14.900] reading kernel comm buffer size
[12:32:14.930] comm buffer size set to 512
[12:32:14.930] reading kernel flash buffer size
thanks
disaster999
Postby disaster999 » Thu Mar 29, 2007 5:21 am
bump...i need help here people
disaster999
Postby swifty » Fri Mar 30, 2007 12:58 am
Sorry, I can't help you, but maybe you can help me. I am also getting the "error loading FTChipID.DLL" message and cannot flash to my ecu since upgrading to ver 1.3. How did you fix this ?
I have only just upgraded and not had time to mess about fixing the problem, knowing exactly how to fix it would ge a great help.
swifty
Postby cboles » Wed Apr 04, 2007 4:05 pm
send me a mail to support@tactrix.com and I will try to help you more. are you consistently seeing the same problem in the log?
colby
Postby chipman » Thu Apr 05, 2007 5:53 am
disaster999 wrote:bump...i need help here people
Just downgrade to 1.29a. ;)
chipman
