Enginuity Edited File in ECUFlash
Postby s2p2 » Fri Mar 16, 2007 11:33 pm
Hi All
Need help badly. I have already managed to connect, download. I have even managed to flash mhy stock file back via ecuflash. But now i have another problem.
When i use enginuity to edit, and try to flash using ecuflash, it always fails!!! What could be the problem. It seems that the error is only after i edit and save in enginuity. Are there any steps/conversion that i have ommitted?
Also, please look at the file, there is something different for ECUFlash and Eginuity. Look at the address for Fuel Cut....(Same File) but address is different
Please help
BC.doc
(138.5 KiB) Downloaded 446 times
s2p2
Postby Nuke » Wed Mar 21, 2007 7:54 pm
which version of both software, are you using
Nuke
Postby blue.taxi » Wed Mar 21, 2007 8:31 pm
is it 'coz ecuflash is a 192kb file & Eginuity is a 160kb file?
blue.taxi
Postby merchgod » Thu Mar 22, 2007 6:40 am
This issue was solved on the Enginuity site. It is because Ecuflash didn't support his rom, so he inherited another rom from the same model whose table defs were not a match for his own. The flashing issue was unrelated.
merchgod
