USDM WRX 2006?
Thu May 11, 2006 4:44 am
by AlanG
Colby,
Whey do you think we'll be able to read / flash 2006 USD WRXs?
Thu May 11, 2006 5:32 am
by JRSCCivic98
How about right now?
Thu May 11, 2006 5:57 am
by Freon
The 2006 is a DBW, just like the 04+ STI, LGT, FXT, etc. It works now.
All the information to get most of the maps is available now as well, although the XMLs have not been created.
Thu May 11, 2006 7:16 am
by AlanG
Ohhh sweet, didn't realize that they were DBW
thanks guys
Tue May 23, 2006 12:16 am
by 2006sti
im having problems with ecuflash at the moment
2006 sti
okay hook cables up
open ecu flash
click open rom from ecu
turn key on
click ok
and no connect or its comes up with a kernel error what am i doing wrong
Tue May 23, 2006 1:36 am
by NeverLies
What's your cable ? OpenPort 1.2 ?
Can you post the log ?
Tue May 23, 2006 5:51 am
by Freon
Did you connect the green test connector?
Do you start to hear your fans cycle after turning the ignition to the "on" position?
Tue May 23, 2006 8:09 am
by 2006sti
i can try to post my logs up but i am on a different computer now i got ecu explorer working fine and ecu edit. One question i have is when will the 06 sti have a ecu def
Tue May 23, 2006 12:26 pm
by Freon
You can go create an ECU def with XMLwrite.
Download your flash from your car, get XMLwrite, follow the instructions for xmlwrite.
Thu Aug 17, 2006 12:29 pm
by MrEvo
did you ever get to read your car?
i would really like to know i am having the same problem.
Thu Aug 17, 2006 2:17 pm
by cboles
We need more specifics from either of you first:
* log files?
* did you connect the test connector?
* what cable are you using?
Thu Aug 17, 2006 7:04 pm
by MrEvo
cboles wrote:We need more specifics from either of you first:
* log files?
ok i did connect the test connector and i did get to read it.
However all i got were the timing maps(two ifnition maps).Is this all i am supposed to get or is there supposed to be more?
I would like to say thanks for this software it did a great deal on my Evo, got an extra 50 horse power.
Thu Aug 17, 2006 9:12 pm
by cboles
I'm working with someone to get the map data for these ECUs. It should be there in the next release.
