Torque Limiter Evo X
Postby student_scheire » Thu Apr 22, 2010 7:55 am
Can Anyone Tell me how the Torque Limiter Maps (#1->#4) function in a EVO X?
I guess the Torque Limiter cuts off to much power of my modificated evo :(
student_scheire
Re: Torque Limiter Evo X
Postby kozmic27 » Sun May 23, 2010 10:27 am
They are the load limits. If they are set to low, you will pop a cel. Just raise them up in 5-10% increments until whatever code or issue you are getting goes away. I believe one is for 1st gear, one is for middle gears, and one is for high gear. The 4th table is an absolute limit table, and usually doesn't have to be messed with, but you can crank it up to. I believe the max value for these tables is 255. You want it to resemble your torque curve in a perfect world.
kozmic27
Return to OpenECU Software
