Outback XT
Outback XT
Postby o313 » Thu Apr 17, 2008 10:38 pm
This is my first go around and I would like some input. this is the ROM info:
USDM OB XT 05 auto
Internal ID:A2WC511R
FlashMethod:sti05
MemoryModel:SH7058
ChecksumModule: subarudbw
Inherits:A2WC510C
I have been lurking about the forums and had heard a few things like using the STI throttle maps etc.... Where do we "get" the maps and what years are compatible? Is my ECU version an older one?
Is there a basic map reading section?
Target Boost A
Target Boost B
Why the two maps?
What is generally considered MAX boost on a stock motor?
Thanks ahead of time for such an amazing group of people!
OrigMAP041708.hex
This is my ROM
(1 MiB) Downloaded 1204 times
o313
anybody?
Postby o313 » Mon Apr 28, 2008 6:45 am
Come on there has to be some experts out there to answer a few questions.
o313
Postby AlGontsov » Fri Dec 12, 2008 12:12 pm
It's may be similar to high and low octane maps, you can make it the same :)
Try to make smooth changes from stock values at the low rpm and load to 2.0-2.2 boost, up to 80-90% wastegate duty, decrease AFR on 1,5-1 at middle and high load areas, add timng up to 10-12 degrees in same areas. And next get the time to drive and look to the logs, corrrect the knocks, e.g. temperature, etc.
AlGontsov
A Big Thanks!
Postby o313 » Fri Dec 12, 2008 12:23 pm
AlGontsov wrote:It's may be similar to high and low octane maps, you can make it the same :)
Try to make smooth changes from stock values at the low rpm and load to 2.0-2.2 boost, up to 80-90% wastegate duty, decrease AFR on 1,5-1 at middle and high load areas, add timng up to 10-12...4-6 degrees in same areas. And next get the time to drive and look to the logs, corrrect the knocks, e.g. temperature, etc.
Thats what I was wondering, Thanks for the initial starting point.
o313
Return to OpenECU Software
