ECU decided enough is enough
Well, it had to happen sooner or later I suppose. I tried another flash today but it failed. Here is the log.
[00:35:21.170] reading ecu programming voltage
[00:35:21.190] programming voltage is 11.99 volts
[00:35:21.190] kernel flash enable
[00:35:21.410] kernel blank flash page: addr: 00028000
[00:35:21.660] erased in 1 pulse(s)
[00:35:21.710] kernel write flash buffer addr: 00028000 len: 00000200
[00:35:21.861] kernel write flash buffer addr: 00028200 len: 00000200
[00:35:22.031] kernel write flash buffer addr: 00028400 len: 00000200
[00:35:22.201] kernel write flash buffer addr: 00028600 len: 00000200
[00:35:22.572] kernel write flash buffer addr: 00028800 len: 00000200
[00:35:22.742] kernel write flash buffer addr: 00028A00 len: 00000200
[00:35:22.892] kernel write flash buffer addr: 00028C00 len: 00000200
[00:35:23.052] kernel write flash buffer addr: 00028E00 len: 00000200
[00:35:23.413] kernel commit flash addr: 00028000 crc32 d53f9b5a
[00:35:23.813] written in 1 pulse(s)
[00:35:23.823] kernel write flash buffer addr: 00029000 len: 00000200
[00:35:23.984] kernel write flash buffer addr: 00029200 len: 00000200
[00:35:24.144] kernel write flash buffer addr: 00029400 len: 00000200
[00:35:26.818] readback fail
[00:35:26.828] WARNING: failure in flashing block
[00:35:26.828] kernel write flash buffer addr: 0002A000 len: 00000200
[00:35:26.948] readback mismatch
[00:35:26.958] WARNING: failure in flashing block
[00:35:26.968] kernel write flash buffer addr: 0002B000 len: 00000200
[00:35:27.078] readback mismatch
[00:35:27.098] WARNING: failure in flashing block
[00:35:27.098] kernel flash disable
[00:35:27.098] readback mismatch
[00:35:27.098] verifying result...
[00:35:27.098] comparing ECU flash memory pages to image file
[00:35:27.098] segment len ecu CRC32 img CRC32 same?
[00:35:27.098] error reading CRC!
[00:35:27.098] error verify checksums! exiting.
Car cranks, pump on etc but no start.
Tried the battery disconnect but no go.
Seems that my PC won't even connect up now.
Does any one have any suggestions what I could try to revive my poor old ECU?
