'Injector Latency' [32-Bit ECUs ONLY]
'Injector Latency' [32-Bit ECUs ONLY]- A more accurate conversion was determined for injector latency. This should be closer to most injector manufacturer's published latency values, although because there is no standard in testing, there still can be wide variances that will require further tuning. Note that this new conversion may not be the same as commercial tuning software, so you should verify this if you are going to use their "recommended" latency values. Change is also reflected in the latest logger definitions.
Hey I was wondering if anyone has trying tuning larger injectors with this different latency conversion.
