Maps on forester has values that is useless
Postby evoixdk » Mon Jan 29, 2007 11:10 am
Hi
I have now read the rom from an european spec. Forester but when I open the rom and read out the values in the maps , the values is
nothing that I can use
If I open the low detonation fuel map A the load says -0,00 all over and the engine speed values are also useless it reads -0 , 16.., 72.. , etc etc
I have read out an EVO IX and every thing works fine on the EVO
What could be wrong
Rom info: Internal ID A2WC401F
Memory Model SH7055
checksum module subarudbw
IVOIXDK
evoixdk
Postby cboles » Thu Feb 01, 2007 10:30 am
[stock answer below]
EcuFlash is not showing any tables for your ROM because no XML definition files has been made for it yet. XML definition files are collections of information about what tables are in a ROM, where they are located in memory, how the numbers in the ROM scale into human readable units, etc. Making definitions is a time consuming process that must be repeated for each different ROM version. I try to contribute definitions when I can, but ultimately it is up to the members of the OpenECU community to help with this aspect of the project. By submitting your ROM image to
http://forums.openecu.org
and
http://enginuity.org
you should be able to get help from others that share an interest in the same vehicle you have. Please also be sure to send me a copy of your ROM as well for our library and future testing.
Postby evoixdk » Thu Feb 01, 2007 11:45 am
Hi Colby
Thanks for your answer
I not sure how to send the rom to you please explain how I do this
Best rgards
evoixdk :wink:
evoixdk
Postby Jon [in CT] » Thu Feb 01, 2007 1:45 pm
evoixdk wrote:Hi Colby
Best rgards
evoixdk :wink:
You should create a new post in the appropriate forum at http://forums.openecu.org/index.php?c=5 and include the ROM image as an attachment. Then you should register at www.enginuity.org and then create a new post in the forum http://www.enginuity.org/viewforum.php?f=8 and follow the instructions provided by http://www.enginuity.org/viewtopic.php?t=128.
Postby evoX » Sat Feb 03, 2007 7:50 am
I have the same problem, with the same car model and rom ID :(
Are there any instructions on how to find the correct addresses in rom ?
evoX
rom post
Postby evoixdk » Wed Feb 07, 2007 11:33 am
I have tryied to post the rom but it doesnt work
:cry:
evoixdk
Postby Freon » Wed Feb 07, 2007 3:37 pm
Try changing the file extension. Try .hex, .rom, and .bin.
Postby evoX » Thu Feb 08, 2007 9:54 am
Hi,
I have tried to rename the file extension in .rom, bin, .hex, and I get the same results with EcuFlash and Enginuity always gives me this error "ECU Definition Not Found"
evoX
Postby Freon » Thu Feb 08, 2007 12:17 pm
That was a response to the other guy saying he couldn't post his ROM. It seems some people have issues posting files if the file extension isn't right. I don't know what is allowed or not.
If you can't get definitions, you should try downloading the latest Enguinity and latest Enguinity definitions. It probably has the best coverage.
http://www.enginuity.org/viewtopic.php?t=360
Postby evoX » Sun Feb 11, 2007 12:22 pm
I have downloaded last week the latest version of enginuity and the latest definitions, but it cannot recognize it.
I can post my rom if the other guy can't post it.
evoX
Postby evoX » Sun Feb 11, 2007 12:42 pm
here it is, I also posted it to enginuity
A2WC401F
2005EDMForester.hex
A2WC401F
(512 KiB) Downloaded 1481 times
evoX
Postby evoixdk » Fri May 11, 2007 11:17 pm
Hi
I have downloaded the ECU difinations from Inginuity but
I am not sure that I do it the right way because I still dont work
Has any off you guys tryied this and does it work
evoixdk
Postby merchgod » Sat May 12, 2007 5:48 am
evoixdk wrote:Hi
The rom posted above has already been added to the latest Enginuity definitions. They are newer than what is included with the main Enginuity download. Get them here:
http://www.enginuity.org/about360.html
merchgod
Postby evoixdk » Tue May 15, 2007 2:18 am
I have dowloaded the newest ecu definations
but it seems that that it doesnt read the ecu codes to the
open ECU sotware
evoixdk
Postby merchgod » Tue May 15, 2007 6:44 am
evoixdk wrote:I have dowloaded the newest ecu definations
open ECU sotware
I'm not sure what you are saying, but if you have the A2WC401F rom, it will work with the new definitions unless you do not have them installed correctly. Perhaps you have another revision? Post up your rom, it might not be the same as what the other guy that posted (change the file extension to .hex).
merchgod
Return to OpenECU Software
