ecuExplorer or ecuFlash
Postby frankis78 » Tue Dec 12, 2006 12:44 am
Hello
What is the best sw to read and flash a subaru wrx 2003mod car?
ecuExplorer or ecuFlash?
I have just got the tactrix cable now, and like to test it..
Regards
frankis78
Postby Twinturbo » Tue Dec 12, 2006 1:16 am
I use Ecuflash for reading ecu definitions and flashing and Ecuexplorer for reading trouble codes and resetting CELs. Think that is the easiest way to do it.
Twinturbo
Postby frankis78 » Tue Dec 12, 2006 2:06 am
Hello
Thanks for replay:)
Can you tell me what you mean with resetting Cells?
Is resetting Cells and clear error codes something you must do after tuning?
Another thing..
Do you need to correct chksumm on ecu like this, after you have modified file :oops:
Its a bit new to me that i can do these ecu by obd. :)
Regards
frankis78
Postby Twinturbo » Tue Dec 12, 2006 3:27 am
CEL = Check Engine Light :wink:
And no, you do not have to do that until the CEL starts to annoy you :wink:
I am not sure about the check sum fix, but I think you only need to do that on DBW ecus (2006-).
And you could remove the the trouble codes you do not want to see (in Enginuity)
Twinturbo
Postby frankis78 » Tue Dec 12, 2006 5:14 am
Hello again twinturbo
Thanks again:)
Do you have any nice file for this car?
Regards
CV38287-read image.zip
(82.17 KiB) Downloaded 565 times
frankis78
Return to OpenECU Software
