I just want to get an idea how many damaged ECU's are out there after using Ecuflash.
Please post what happened and if you got any error messages.
Well, let me go first.
05 Legacy GT MT. Flashed a change to the ECU and it said that CRC's are all Ok. Double checked them by doing the ECU compare and again all CRC's were ok. ECUFLASH said to turn ignition off and remove the jumper. Did that.. Car won't start. Getting ER HC on the odometer display. Checked the green connector 10 times to make sure it's disconnected.
I also removed the ECU from the car and left it out overnight. Next day same problem. Car won't start. Ecuflash says
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
kernel get version
validating denso kernel ram area addr: FFFF0000 len: 0008
Also tried ecuexplorer but it doesn't connect.
