New GUI version of EcuFlash
Postby Jeramie » Tue Nov 29, 2005 8:25 am
That would be great for lazy people like me :D . Thanks
Jeramie
Postby ghostwrx » Wed Nov 30, 2005 10:08 am
I am simple minded at time i placed the dll files in the wrong folder, thanks for the help.*repeatedly smacks self in head*
ghostwrx
Postby Freon » Thu Dec 01, 2005 5:17 pm
No workie on my 2004 USDM STI, which is DBW, while the WRX is not. I didn't expect it to work...
Neverlies, exactly what model year, market (edm? usdm? jdm?), and model is your car?
I hooked everything up, hit the Read ECU button, turned the key to ON, then clicked OK on the dialog box for ECUflash. I tried about a dozen times.
Here's my flash setup and log files (ecuflash and portmon):
http://freon.shackspace.com/ecu%20and%2 ... /flash.jpg
http://freon.shackspace.com/ecu%20and%2 ... /error.log
http://freon.shackspace.com/ecu%20and%2 ... /flash.log
The portmon log looks ok to me. I just don't think the DBW STI ECU is as close to the cable throttle WRX as you are thinking. But if you have a DBW STI, then nevermind, maybe I'm screwing up.
Postby cboles » Thu Dec 01, 2005 5:32 pm
The DBW ECUs will not work until I add support for them. It's a completely different ECU.
Postby Freon » Thu Dec 01, 2005 5:36 pm
Gotcha, I kinda figured... :cry:
Let me know if I can help in any way. Well, besides mailing my ECU to you...
Postby cboles » Thu Dec 01, 2005 5:46 pm
Somebody *please* mail me an ECU!!! I'm willing to buy it if the price is reasonable. This is all that is holding me up from DBW support...
Postby Freon » Thu Dec 01, 2005 6:01 pm
I'm researching. I'll see what I can find. My car whispered to me "flash me, flash me" as I was prodding under the dash, I swear.
Postby Freon » Mon Dec 05, 2005 9:53 am
cboles wrote:Somebody *please* mail me an ECU!!! I'm willing to buy it if the price is reasonable. This is all that is holding me up from DBW support...
YGPM.
Postby ahains » Thu Dec 08, 2005 1:16 pm
Here are the msvc*71.dll files needed to make it work on XP Pro, and I would assume are correct for XP Home as well.
msvc(rp)71.zip
(305.56 KiB) Downloaded 814 times
ahains
Postby peewee » Thu Dec 08, 2005 2:58 pm
Colby,
I have found here in the Netherlands a DBW ECU from a Sti with auto gearbox.
It's the one with the big SH7055 processor in it. I can lend it from a guy here who import used engine's from Japan.
I can send it to you if you want, let me know.
Paul
peewee
Postby Kosti » Mon Nov 06, 2006 4:25 pm
This ecuflash file on the first page contains the worm PE_TENGA.A :shock:
Kosti
Postby SubieGuy » Tue Nov 07, 2006 10:15 am
Yep, my antivirus s/w also detects this:
The Win32/Gael.3666.A was detected in ECUFLASH_SETUPV101.EXE
Hope your system is fine Colby. I'd definitely recommend a through virus check...
SubieGuy
Postby zilog357 » Wed Nov 08, 2006 2:18 pm
My system too. PE_Tenga virus.
Also, the file to be downloaded is only fifty-something kilobytes and
not the original Mega-Byte size.
zilog357
Postby goixiz » Fri Nov 17, 2006 7:01 am
so where can i get a "clean" version of the new ECUFLASH
goixiz
Postby Jon [in CT] » Fri Nov 17, 2006 8:46 am
Return to OpenECU Software
