cboles wrote: Also, the app will only work with OpenPort hardware, unless you are using a FTDI232BM based USB to serial adapter along with an appropriate ISO9141 interfaace. The reason for this is that there are parts of the 04-05 firmware and my kernel use obscure baud rates which normal UARTs won't hit.
So i should not waste my time trying this with the Delta Dash obd2 connector and IOGear serial to usb adapter?
