Maps on forester has values that is useless
Postby evoixdk » Wed May 16, 2007 10:05 am
Perhaps I do something wrong
How can I be sure that the open ECU software reads the rom definations
and what do you guys do when you have dowloaded the rom defination
evoixdk
Postby evoixdk » Thu May 17, 2007 12:32 pm
I can download the ECU difinitions with no problem
But where or how to place theese difinitions so the open Ecu software
can use the difinitions
evoixdk
Postby evoixdk » Fri May 18, 2007 6:20 am
Here is the rom
kimsub.hex
(512 KiB) Downloaded 864 times
evoixdk
Postby merchgod » Fri May 18, 2007 7:18 am
that is the a2wc401f. This is supported by the latest Enginuity defs:
1. Download and install Enginuity 0.4.1b -> www.enginuity.org
2. Download, unzip and place the updated ecu defs 0.784b in the Enginuity main directory replacing the existing file -> http://www.enginuity.org/about360.html
3. Run Enginuity and open rom
4. When flashing with Ecuflash make sure the flashmethod tag in A2WC401F.xml is sti04 (ecuflash\rommetadata).
merchgod
Postby evoixdk » Sun May 27, 2007 11:17 pm
It works now , perfect :wink:
But when I look at the timing map it looks like a timing map for
an NA engine and not a turbo charged engine !!
evoixdk
Return to OpenECU Software
