can't flash my wrx 02 edm
Sat Nov 22, 2008 6:43 am
by divo
i can't flash my wrx 02 EDM with a taxtrix cabel. is there a other way to do it.
the wrx 02 edm is not suport for this kabel
Sun Nov 23, 2008 4:44 pm
by radsdau
That vehicle should be supported by Tactrix cables (unless it's a Mitsubishi-only type).
Which cable do you have?
Mon Nov 24, 2008 8:38 am
by divo
i have this cabel:
http://www.tactrix.com/product_info.php ... 1ba2d52f92
its a original tactrix but it wil not work
Mon Nov 24, 2008 3:34 pm
by radsdau
The OpenPort2 cable should work with every 01- WRX that I've heard of, can't say for sure if 02 EDM is the same, but I can't imagine it's any different.
"it will not work" is not a particularly helpful statement to help anyone diagnose this. How about a few more details? Is it the driver installation you're having problems with? What OS are you running? Does ECUFlash detect the cable? Are you selecting the correct flash hookup method? Is your car in test mode (fans cycling)?
Tue Nov 25, 2008 12:50 pm
by divo
i have instal the last version of ecu flash, this is the read log:
[21:37:02.561] Version 1.40.2178
[21:37:02.576] 19 memory models read.
[21:37:02.576] scanning for metadata models in C:/programma´s/ecu flash/EcuFlash/rommetadata
[21:37:07.100] 319 ROM metadata models scanned.
[21:37:07.100] checksum module "subarudbw" loaded.
[21:37:07.100] flashing tool "wrx02" loaded.
[21:37:07.100] flashing tool "wrx04" loaded.
[21:37:07.100] flashing tool "sti04" loaded.
[21:37:07.100] flashing tool "sti05" loaded.
[21:37:07.100] flashing tool "mitsukernel" loaded.
[21:37:07.100] flashing tool "mitsukernelocp" loaded.
[21:37:07.100] flashing tool "shbootmode" loaded.
[21:37:07.256] flashing tool "shaudmode" loaded.
[21:37:07.256] flashing tool "subarucan" loaded.
[21:37:20.448] J2534 API Version: 04.04
[21:37:20.448] J2534 DLL Version: 0.50.2176 Oct 20 2008 17:50:12
[21:37:20.448] Device Firmware Version: 1.01.2145
[21:37:27.023] denso02_bootloader_cmd_start
[21:37:28.599] denso02_bootloader_cmd_start
[21:37:30.143] denso02_bootloader_cmd_start
[21:37:31.719] denso02_bootloader_cmd_start
[21:37:33.263] denso02_bootloader_cmd_start
[21:37:33.950] kernel get version
[21:37:34.480] interface close
[21:37:34.558] interface close
en i have instal romraider, with the last ecu def. en log def.
the romraider logger can't conect : unable to send ecu init.
the com port is selected ok
cable is connecter ok
i hope any one can help me
