I know both will work. I won't be flashing anything other than my Legacy. IS the 1.3M cable better for future upgrades? Is it capable of faster transfers, or other things that the 1.2 cable can't do.
Anyone?
Evo4Mad wrote:1.3M is fine.. it is better.
No. It's most likely a device driver issue. EcuFlash for Mitsubishis and drive-by-wire Subarus needs to use FTDI's D2XX device driver, so that's what is shipped and installed when you order a 1.3 cable. The ecuExplorer datalogger needs to use FTDI's virtual COM port (VCP) device driver. FTDI now has a new driver for Windows, called Common Driver Model (CDM), which can support both EcuFlash and ecuExplorer.LGTspore wrote:While I've been able to read the ROM off my Legacy GT using the 1.3 cable, I haven't been able to do data logging...
You fellas reckon it's a cable issue?
Thks!
Jon [in CT] wrote:No. It's most likely a device driver issue. EcuFlash for Mitsubishis and drive-by-wire Subarus needs to use FTDI's D2XX device driver, so that's what is shipped and installed when you order a 1.3 cable. The ecuExplorer datalogger needs to use FTDI's virtual COM port (VCP) device driver. FTDI now has a new driver for Windows, called Common Driver Model (CDM), which can support both EcuFlash and ecuExplorer.LGTspore wrote:While I've been able to read the ROM off my Legacy GT using the 1.3 cable, I haven't been able to do data logging...
Thks!
The new CDM device driver can be downloaded from:
http://www.ftdichip.com/Drivers/D2XX.htm
Installation instructions are at:
http://www.ftdichip.com/Documents/InstallGuides.htm
