02 WRX timeout on read for ECU Type
Hi All,
I did the following:
1) Key off
2) connect jumper
3) Don't connect green connectors (test mode)
4) Run Ecu Explorer (Debug console on)
5) Adjust comm port setting as suggested in Manual (also tried with standard settings)
5) Connect Openport 2.0 plug
6) Turn key to ON
I get a continuous stream of:
08:32:31.609 - to ECU : QueryECUType
08:32:32.859 - Response Timeout - QueryECUType
08:32:32.859 - QueryECUType failed with 4103 [0x1007]
When I run RomRaider Logger, I get a good connection to the ECO and can log values.
Any ideas?
Gar
1) Key off
2) connect jumper
6) Turn key to ON
Any ideas?
Gar
