I have a 2005 Baja Turbo that I am trying to get EcuFlash to read from but it doesn't seem to recognize the ecu.
My system:
Gateway FX 6860 (C2D Xtreme 3ghz)
4GB Ram
Windows Vista Home Premium 64 Bit /w SP1
Tactrix OpenPort 2.0
EcuFlash 1.42.2595 /w latest definitions
This is the output I get from EcuFlash:
[22:19:29.543] J2534 API Version: 04.04
[22:19:29.543] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[22:19:29.543] Device Firmware Version: 1.10.3020
[22:19:31.188] kernel get version
[22:19:31.562] SSM2 init
[22:19:31.702] SSM2 ECU ID is 3F 12 40 41 06
[22:19:31.796] Requesting Seed...
[22:19:31.843] Sending Key...
[22:19:32.467] interface close
[22:19:32.482] interface close
EcuFlash shows on the bottom right Tactrix OpenPort 2.0 cable on Com 23.
At first I thought it was the drivers for the cable so I completely uninstalled any serial drivers I might have.. rebooted and reinstalled and the cable is instantly recognized and drivers installed. EcuFlash shows it's connected and i can see the lights flashing when it's trying to connect to my ecu but it seems like it doesn't recognize it.. *scratching head*
The weird thing is if I try and do this with the car running instead of just the key in the on position the car will shut off and throw up a CEL...
I am pulling my hair out.. any idea's what I may be doing wrong? I dont have access to another laptop otherwise i'd try that.... Anyone in the Bremerton/Silverdale area?
