Page 1 of 2
evo 7 ecu
Mon Oct 24, 2011 4:21 pm
by wcassar1985
Hi all, I am the owner of a mitsubishi lancer with 4g63 engine anf also have evo7 ecu fitted to it too.
I bauht the openport cable too.
which is the best thing to do first, to read from ecu?
and than save as it and edit it?
regards
Re: evo 7 ecu
Tue Oct 25, 2011 6:22 pm
by radsdau
Correct. Save a copy of your current/original ROM before you do anything else. If it all goes pear-shaped, you can just put it back to how it is now.
And make a backup. These ROMs have security codes specific to your car, so if you lose it, you'll be stuck with a car that doesn't work.
Start tuning from a copy of your ROM.
Re: evo 7 ecu
Tue Oct 25, 2011 7:45 pm
by wcassar1985
I used the evoscan software 2.8
I read from the ecu and it save sort of file +++++.hex on the left side.
How can i save a copy of it?
regards
Re: evo 7 ecu
Sat Oct 29, 2011 12:55 pm
by todd-w
add these to your ecuflash rommetdata
Re: evo 7 ecu
Mon Oct 31, 2011 9:25 am
by wcassar
what are these files neccessary for?
regrads
Re: evo 7 ecu
Mon Oct 31, 2011 9:33 am
by wcassar
cause i m still a beginner in using the evoscan software.
Re: evo 7 ecu
Mon Oct 31, 2011 1:27 pm
by todd-w
they are definition files necessary to make the rom viewable , get a copy of ecuflash below
http://www.tactrix.com/index.php?option ... &Itemid=58
Re: evo 7 ecu
Tue Nov 01, 2011 4:59 am
by wcassar
ok, i have downloaded it......now were should i put the 2 files please?
regards
Re: evo 7 ecu
Tue Nov 01, 2011 1:30 pm
by todd-w
save to my computer/C:/program files/open ecu/ecuflash/rommetdata/misubishi/evo if it asks to replace existing files click yes
Re: evo 7 ecu
Fri Nov 04, 2011 5:03 am
by wcassar
thats fine i have managed to do it.
Now I tried to connect with the ecu flash and some errors are poping out and not letting me connect to my ecu.
Are there any options that i shall do to connect well?
thanks
regards
Re: evo 7 ecu
Sun Nov 06, 2011 1:06 pm
by todd-w
what errors ??
Re: evo 7 ecu
Wed Nov 09, 2011 10:23 am
by wcassar
no reply from ecu.....
regards
Re: evo 7 ecu
Wed Nov 09, 2011 7:08 pm
by radsdau
Double check the flash-enable connector is plugged in correctly too; that's important.
Re: evo 7 ecu
Wed Nov 09, 2011 9:39 pm
by wcassar
with regards to cable i think that is ok because with the evoscan i succeed to connect and clear the fault codes.
regards
Re: evo 7 ecu
Thu Nov 10, 2011 3:48 pm
by radsdau
Connecting to read codes and connecting to reflash are not the same. Reflashing requires the extra connector, because it forces the micro to run 'boot' code. You can't reflash without that.
