I have a Aus spec MY01 WRX. I have the Tactrix Open Port cable.
I have ECUExplorer and ECUFlash and Enginuity on my lap top.
I took itout to the car and connected the green plugs under the dash as i only want to see if i can read etc atm.
Had the car turned off, loaded up ECUExplorer and i get the message "Error, can't open log etc, 5x00", or somethinh like that.
I go to tools and select my ECU ie: 2001-2005 iutside U.S.
I go to read ROM and a box appears,save etc. Typein the file name to save, then a box appears. Kernell blah, blahh etc and either Aborted or can't connect.
What is the process? i have tried it with the ignition on as well.
Does the Openport need drivers?, where can i get these?
Thanks.
