I tried to work with EVO-ECUs using EcuFlash 1.22 and have discovered some problem (???) with connect stabilty.
ECU replies excellent on 9600-init strings and after switching on high baudrate (62500 bps) it doesn't continue work in bootstrap-mode.
Typically log is as follows:
[07:47:32.487] Version 1.22.373
[07:47:32.487] 9 memory models read.
[07:47:32.627] 62 ROM metadata models read.
[07:47:32.627] flashing tool "wrx02" loaded.
[07:47:32.627] flashing tool "wrx04" loaded.
[07:47:32.627] flashing tool "sti04" loaded.
[07:47:32.627] flashing tool "sti05" loaded.
[07:47:32.627] flashing tool "evo" loaded.
[07:47:32.627] flashing tool "shbootmode" loaded.
[07:47:32.627] flashing tool "shaudmode" loaded.
[07:47:32.627] error loading FTD2XX.DLL
[07:47:43.883] sending init sequence 1 (0001)
[07:47:44.925] got 0x05 response
[07:47:44.925] sending init sequence 2
[07:47:44.955] got 0x1B response
[07:47:44.955] sending init sequence 3
[07:47:45.375] entering bootloader
[07:47:45.385] sending kernel size (3428)
[07:47:47.418] error sending kernel size
But this situation occurs not everytime. Sometimes (absolute unpredictable) it works normal - enter bootstrap, load kernel, read and write...
I tested this on the car and on the table with several ECUs (evo7/8 ) I have by hand - all of them show the same behaviour...
I don't think that the slow interface hardware is a reason - the same i/face works fine and stable with Audi-VW ECUs on 125kbaud.
Have anyboby and aspecially cboles any comments?
