the USB DLC interface cable >
Postby jak » Fri Apr 07, 2006 6:20 am
I see mention of an open port 1.2
I think I bought the techtricks 1.0?
are there 2 diferent cables? or is this a SW diference
if anyone would be kind enough to explain I sure would apriciate it
take care
JAK
jak
Postby qoncept » Fri Apr 07, 2006 6:57 am
Openport 1.2 is available on tactrix.com.. You got your cable there recently, right? If it was in the last few months it should be a 1.2.
It is a hardware difference.
Postby FrSTi » Fri Apr 07, 2006 8:15 am
Regarding the DBW flashing issue, how can we be 100% sure our cable is 1.0 or 1.2, Colby ?
FrSTi
Postby FrSTi » Sun Apr 09, 2006 10:53 am
FrSTi wrote:Regarding the DBW flashing issue, how can we be 100% sure our cable is 1.0 or 1.2, Colby ?
Bump
FrSTi
Postby gethin » Sun Apr 09, 2006 11:27 am
If you scan for OpenPort in the registry then it will show up.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\Vid_0403&Pid_6001\TX13UIzX
Gethin.
gethin
Postby cboles » Sun Apr 09, 2006 10:29 pm
The OpenPort 1.2 has the TX______ serial number like gethin points out. I also didn't sell any OpenPort 1.0's after 10/1/2005.
