Wich open port cable??
Postby kidthewiz » Tue Jan 13, 2009 11:39 am
i made a little bit of research on this forum, but honestly i really don't get it ;)
I would like to be able to read my "Check Engine" code on my 2001 Subaru Outback 2.5
Can someone tell me wich hardware do i need to read the codes.
one of my friend use the open port 1.3 cable for is WRX 2002, is it the same setup?
regards,
Eric
kidthewiz
Re: Wich open port cable??
Postby AlGontsov » Wed Jan 14, 2009 12:30 am
1.3 is not manufacured since OP2.0 is released.
You should use v1.3 with the most of logging software (EvoScan, RomRaider), 2.0 is suppurted only by the RomRaider.
AlGontsov
Postby Sasha_A80 » Wed Jan 14, 2009 4:11 am
Such a cable (and software) maybe incompatable with 2001MY. You do need to check friend's setup with your car.
SSM2 Subaru Select Monitor protocol is a must, MY2001 may support SSM1.
Sasha_A80
Postby kidthewiz » Wed Jan 14, 2009 10:31 am
Many thanks,
i will check this out with my friend to see if his interfaces fit my 2001 subaru outback!
Regards!
kidthewiz
