Hey all,
I own an evo4 that i installed an evo 7 ecu into, i repined all the nessassary crap to get it running (sas, rans, disconnect ayc pin and such)
car runs and drives ok.
Now the problem im having is i cant get my cable to connect to the car, i can read obdII fine with no problems, yet when i try to read from the ecu i get an error and it wont connect,
with the extra pin that the 7 uses (79) i just ran a cable from that to one of the pins on the white plug on my reflash cable,
does anyone know if anythign else needs to be done to make the evo 7 ecu be able to flash in a evo 4
or how to build a bench cable for it?
thanks
scott
