Presentation and problem with Ftdi connection ttl-usb cable.
Postby Ramonet » Mon Nov 17, 2008 12:56 pm
Hello!
I appear from a town of Alicante (Spain). I have a Subaru Impreza Gt turbo (Wrx - 211ps) of the year 1996.
The problem is that when has the contact of the given car it recognizes the device well to me. When I start the car does not stop to connect and to disconnect the device usb.
With the contact of the key (usb working) subaru select monitor does not recognize anything.
Somebody knows the solution?
The error consists of call 92 problem?
Ftdi cable ttl to Usb 5V (correct cable).
Thanks for your time. Greetings from Spain
P.D. Pardon by the translations but is made by a translator, jejej.
Ramonet
Postby Ramonet » Sat Nov 22, 2008 10:25 am
If it is not understood to say it and I put a video.
Thanks.
Ramonet
Postby Jon [in CT] » Sat Nov 22, 2008 1:48 pm
What is the name of the software program you use?
Your Subaru only supports the old SSM1 communications protocol. Go to these web pages for help with SSM1.
http://www.vwrx.com/index.php?pg=selectmonitor
http://www.graphics.cornell.edu/~v/b10scan/index.html
http://www.alcyone.org.uk/ssm/
Postby Ramonet » Mon Nov 24, 2008 4:58 am
Use the Ssm1.
The problem I have when starting the car, that usb is connected and disconnected automatically.
Makes lack an amplifier of signal?
Greetings and thanks for your answer.
Ramonet
