ECU won't connect
ECU won't connect
Postby upp_cos » Tue Jul 29, 2008 1:34 pm
I've been trying to connect this 06 wrx sti, and it won't do it. I was running 1.34 didn't work. Upgraded to 1.35, didn't work. After some reading I downgraded to 1.29, still doesn't work. With .34-35 I was getting an error message of interface-closed. Now with 1.29 I'm getting this:
[00:45:40.140] Version 1.29.906
[00:45:40.140] 8 memory models read.
[00:45:55.671] 254 ROM metadata models read.
[00:45:55.671] checksum module "subarudbw" loaded.
[00:45:55.765] flashing tool "wrx02" loaded.
[00:45:55.765] flashing tool "wrx04" loaded.
[00:45:55.765] flashing tool "sti04" loaded.
[00:45:55.765] flashing tool "sti05" loaded.
[00:45:55.796] flashing tool "mitsukernel" loaded.
[00:45:55.796] flashing tool "mitsukernelocp" loaded.
[00:45:55.796] flashing tool "mitsubootloader" loaded.
[00:46:12.640] ssm2_init
[00:46:12.796] ECU ID is 43 12 59 40 06
[00:46:12.796] ssm2_cmd_0x81
[00:46:12.843] ssm2_cmd_0x83
[00:46:12.890] denso challenge-response
[00:46:12.937] challenge is 81 EB 36 E9
[00:46:12.937] response is 08 3A 88 99
[01:21:44.921] ssm2_init
[01:21:45.062] ECU ID is 43 12 59 40 06
[01:21:45.093] ssm2_cmd_0x81
[01:21:45.125] ssm2_cmd_0x83
[01:21:45.171] denso challenge-response
[01:21:45.218] challenge is 79 F6 64 F2
[01:21:45.218] response is 7F E0 5F C0
[01:21:54.781] ssm2_init
[01:21:54.937] ECU ID is 43 12 59 40 06
[01:21:54.937] ssm2_cmd_0x81
[01:21:54.984] ssm2_cmd_0x83
[01:21:55.031] denso challenge-response
[01:21:55.078] challenge is 4E CE BD F5
[01:21:55.078] response is CE 65 39 6D
[01:22:10.531] ssm2_init
[01:22:10.671] ECU ID is 43 12 59 40 06
[01:22:10.671] ssm2_cmd_0x81
[01:22:10.718] ssm2_cmd_0x83
[01:22:10.765] denso challenge-response
[01:22:10.812] challenge is 1A 74 75 F3
[01:22:10.812] response is B5 2F F0 99
You can see in this log I tried 3 different times to connect, and every time I get a different Challenge/response? Don't even know what the hell that is. I'm in no way computer technical, I only know cars. Any help would be muchly appreciated, as this thing is sitting on my dyno. I'm using a Traxis 1.3u cable and it's worked many times before. This ecu has apparently already been tuned once but with a previous owner so we don't know where or with what.
Any help would be much appreciated.
CK
upp_cos
Postby upp_cos » Tue Jul 29, 2008 3:14 pm
Well just did some research on the car and found out that it's been ecutek'd...
So anyone know if the 05 STI ecu will work in place of the 06? I happen to have one sitting around
Thanx
CK
upp_cos
