Could not get access to the ECU on LGT JDM =\
Trying to get access to the ECU using Tactrix OpenPort and EcuFlash, connecting two green jumpers (http://www.scoobypedia.co.uk/index.php/Knowledge/ConnectingToYourECU#toc4) on the passenger side. The "Test engine" mode should start and I should get a flashing CEL, but I don't. After this the car is working in normal mode, but as I know in “test engine” mode the car should not start at all. CE lamp is working OK, when I start the engine it’s ON, then it’s goes off, like it should be..
In RomRaider I can check “Test Mode Connector” switch, and it’s off. All other switches work OK.
Anyway, connecting Tactrix OpenPort to my laptop, start EcuFlash, select LGT ’05 template, switch ignition key to “ON” position and press connect. It’s trying to connect, but gets an error (see screenshot).
So, I can't use EcuFlash to read my ECU rom =\
Does anyone know what can it be? Maybe I should connect anything else? Or may be it's something else, for ex. in car alarm system or immobilizer?
P.S. I tried this (http://www.autodata.ru/news.osg?idr=2&idt=14&idn=986) method too (connect the white connectors), but no luck.
2005 Subaru Legacy B4 2.0GT 5MT JDM
Thanks!
Thanks!
