Brazilian 2003 WRX.
Brazilian 2003 WRX.
Postby fel1979 » Wed Mar 05, 2008 10:56 am
Hi,
I was trying to use the open source, I was able to download the data however when I try to use the file I got this screen.
I also attached the read image.
Could someone give me hand?
Regards
Felipe
read image.bin
This is a stock brazilian 03 WRX not the bugeye.
(160 KiB) Downloaded 1246 times
fel1979
Postby radsdau » Wed Mar 05, 2008 3:28 pm
Here's what XMLWrite made up. I've attached the 'fixed' version as well, for ECUFlash 1.31 onwards.
*No guarantees they are right, ok? This is just straight out of XMLWrite!
A4RM100F Def.zip
Raw XMLWrite output.
(17.7 KiB) Downloaded 439 times
Postby Jon [in CT] » Wed Mar 05, 2008 3:57 pm
An alternative, which will result in XML definitions for both EcuFlash and RomRaider, is to register at http://www.RomRaider.com and then post a link to this thread in the forum there at http://www.romraider.com/forum/forum8.html. Ask there whether someone can provide the XML definitions for your ROM image.
This is your best chance for the ability to log and edit your ECU.
Postby Alex Maroto » Sun May 04, 2008 8:50 pm
I honestly tried both files and data still doesn´t have any sence when read it!!
GC stock maps 520672 WRX 2003.hex
(160 KiB) Downloaded 848 times
Alex Maroto
