Innovate Logworks Plug-In for Predator Data
Innovate Motorsports has released a plug-in for their Logworks tuning software which will incorporate Diablosport Predator OBD/CAN Datainto Logworks for analysis with your Air Fuel Ratio Data in real time.
This is very similar to the Tactrix/OpenPort solutionthat's been wildly popular for Mitsubishi and Subaru owners (and extremely useful to tuners). With this new Predator plug-in, the same level of coordinated and synchronized data is now available for a wide range of American made cars and trucks.
Diablosport is a leading developer of flash tuning tools for Ford, GM, and Dodge (Diesel, Gasoline, and Flex Fuel/Ethanol). Now, with the new plug in for for LogWorks, you can integrate data from the Predator OBD2/CAN interface with data from any and all Innovate products. For example, log wideband Air/Fuel Ratio data from an LC-1 along with RPM, MAF, injector duty cycles, and other parameters from your factory ECU.
All of the data is completely synchronous, so you know exactly where you have a lean or rich zone in your fuel map. The Predator lets you adjust many fuel-related variables, but without precise measurments, how do you know what to change? Now you can know.
Also, you can email a log file to Diablosport's network of Authorized Tuners, and they can email you a new custom tune. (The Predator is intended for fine tuning stock or mildly-modified vehicles. If you are making major modifications, you'll probably need to get a custom tune).
We'll be making special package deals available for customers buying both the Predator and a corresponding Innovate Motorsports product.
