Unable to connect to vehicle interface
Postby abd » Sat Apr 21, 2007 6:52 am
Background:
I am trying to read the ECU on my Euro EVO 9 2006.
I am using a PC with win xp, a tactrix cable and ecuflash 1.3.
I get these errors when trying to read the ecu on my EVO 9 after I have connected the usb-cable, turned on the ignition, selected "read from ecu" and selected 2006 evo9/at in the list and pressed OK.
[23:27:37.140] 121 ROM metadata models read.
[23:27:37.140] checksum module "subarudbw" loaded.
[23:27:37.140] flashing tool "wrx02" loaded.
[23:27:37.140] flashing tool "wrx04" loaded.
[23:27:37.140] flashing tool "sti04" loaded.
[23:27:37.140] flashing tool "sti05" loaded.
[23:27:37.140] flashing tool "mitsukernel" loaded.
[23:27:37.140] flashing tool "mitsukernelocp" loaded.
[23:27:37.140] flashing tool "mitsubootloader" loaded.
[23:27:49.531] unable to connect to vehicle interface.
I have tried to downgrade to ecuflash 1.28 but it gives an other error, it says something like "sending init 1, sending init 2, sending init 3" then it gives a popup like "error, check the log"
Cable seems to work as far as i can see.
Please help, I am getting more and more frustrated..
The ECU is supposed to be stock. I had problems running EVOscan also, mitsulogger does work though..
Thanks..
abd
Postby abd » Sat Apr 21, 2007 10:08 am
Have tried again to re-install everything but still can't connect..
[00:05:58.171] Version 1.30.1095
[00:05:58.171] 8 memory models read.
[00:05:59.250] 145 ROM metadata models read.
[00:05:59.250] checksum module "subarudbw" loaded.
[00:05:59.250] flashing tool "wrx02" loaded.
[00:05:59.250] flashing tool "wrx04" loaded.
[00:05:59.250] flashing tool "sti04" loaded.
[00:05:59.250] flashing tool "sti05" loaded.
[00:05:59.250] flashing tool "mitsukernel" loaded.
[00:05:59.250] flashing tool "mitsukernelocp" loaded.
[00:05:59.250] flashing tool "mitsubootloader" loaded.
[00:06:17.765] unable to connect to vehicle interface.
In the bottom right of ecuflash it reads something like: Openport 1.3 for Mitsubishi xjyz23
I now realize that I get exactly the same error when I plug-in the USB cable in the computer without plugging it into the car.. So i have no connection at all to the ECU..
BTW, I got evoscan to work by changing regional settings for , and .
abd
Postby japerformance » Wed Apr 25, 2007 7:21 am
pm me and ill send ya the ecu unlocker for the evo 9 , is it a fq model
japerformance
Postby japerformance » Wed Apr 25, 2007 7:22 am
japerformance
