Jumper Harness Kit From Subaru
Postby Jon [in CT] » Tue Dec 20, 2005 8:09 am
I wanted to let people know that Subaru sells a Jumper Harness Kit for ECU/TCM reprogramming. It is part # 24036AA010. It's pricey (list $28.98) but it should be available from any Subaru dealer's parts dept. I've also attached a document which shows which jumper to use for recent US Subaru models.
jumper_harness.pdf
Jumper Use Matrix
(78.46 KiB) Downloaded 1559 times
Postby Hitokiri » Tue Dec 20, 2005 11:35 am
cool!
interesting to see that the STI do not require a flash block connector.
Postby GotWRX03 » Wed Dec 28, 2005 7:03 am
is this the same as those jumpers we install under the steering rack, in order to be able to reflash?
GotWRX03
Postby BLUES » Sun Jan 08, 2006 7:25 pm
any reason why i can't download the pdf attachment?
BLUES
Postby intrawrx » Mon Jan 09, 2006 4:08 am
you need to register as a member.
intrawrx
Re: Jumper Harness Kit From Subaru
Postby crispyduck » Mon Jan 09, 2006 6:06 am
Jon [in CT] wrote:I wanted to let people know that Subaru sells a Jumper Harness Kit for ECU/TCM reprogramming. It is part # 24036AA010. It's pricey (list $28.98) but it should be available from any Subaru dealer's parts dept. I've also attached a document which shows which jumper to use for recent US Subaru models.
Jon, thanks for that.
For anyone in the UK I've just called my local dealer and this part number is the same. It's £44.23 + VAT! It would be cheeper to order from the US and have is shipped over. Rip of Britan big time.
Postby BLUES » Mon Jan 09, 2006 6:44 am
intrawrx wrote:you need to register as a member.
i have?
BLUES
Postby cboles » Mon Jan 09, 2006 10:08 am
I'm working on sourcing these for a lower cost. It involves buy a lot of the parts from Japan and doing the wiring though. :?
