EcuFlash with Mitsubishi Legnum/Galant VR-4 6a13tt
Postby Kenny » Sun Nov 12, 2006 2:24 pm
I am interested in getting EcuFlash working on this platform.
I have the OpenPort 1.3M cable and have sucessfully connected to the ECU with EvoScan, however this requires grounding pin 1 of the ODBII connector.
Not quite such a easy road with EcuFlash however as when I try download the ROM I get the following
sending init sequence 1 (0001)
sending init sequence 1 (0003)
sending init sequence 1 (FFFF)
no response to any known code
So I tried (Just in case) with the unlocker running
sending init sequence 1 (F0F0)
I have tried with the diagnostic pin (pin 1) grounded and not with no difference.
Is there anything else I can try to get the ROM? I also have a spare ECU and if it helps I could post pictures of the ECU board etc.
Any suggestions as to how I could try get this utility to work with the ECU to download the ROM would be greatly appreciated :)
ECU Code is MR5 and some other numbers
Cheers,
Kenny
/edit: In case it matters, this is a JDM vehicle.
Kenny
Postby YP » Mon Nov 13, 2006 3:14 am
Your processor unsupported by EcuFlash.
Here is the rom ftom your car.
md340289.zip
(39.76 KiB) Downloaded 1216 times
YP
Postby NeverLies » Mon Nov 13, 2006 9:04 am
YP, did you extract it with your own software ?
Postby Kenny » Mon Nov 13, 2006 12:31 pm
YP wrote:Your processor unsupported by EcuFlash.
Thanks.
How did you get the ROM? Also, is there any chance of getting EcuFlash support, or is it impossible to flash the ECU?
Cheers,
Kenny
Kenny
Postby YP » Tue Nov 14, 2006 12:10 am
I get this rom with my own software and hardware. I can not share this program, because I can not any support for this. Users can temporary kill ECUs with this s/w.
About ECUFlash support - ask colby.
YP
Postby NeverLies » Tue Nov 14, 2006 12:47 am
No problem with the support, I wanna try this one on a mitsubishi ECU which is not in a mitsu :D
Postby Rotawerx » Tue Nov 14, 2006 12:57 am
temporarily...? Thats not a problem then is it! :P
haha, been keen to see how it works though.
Rotawerx
Postby Kenny » Tue Nov 14, 2006 3:04 pm
YP wrote:I get this rom with my own software and hardware. I can not share this program, because I can not any support for this. Users can temporary kill ECUs with this s/w.
I am interested to know what hardware you use, and if the sofware is written by you. I am a programmer myself actually and as such given somwhere to start would be keen to have a go at this myself.
Of course best scenario would be for EcuFlash to eventually support this ECU as it would make life a lot easier... and we all like the idea of an easy life :wink:
Cheers,
Kenny
Kenny
Postby colombiano » Tue Dec 26, 2006 8:35 am
how did u grounded pin 1 coz i have openport 1.3 and is not connecting either on evoscan(i have galant 8g 1999)
colombiano
Postby AderC » Wed Dec 27, 2006 2:23 pm
This link shows you how to ground the correct pin. Photos are from an FTO but the Galant is exactly the same
http://www.ftowa.com/html/workshop/workshopart07.html
aDe
AderC
Postby AderC » Tue Aug 28, 2007 6:00 am
I've now used ecuflash v1.3.1 to download the ROM from my ECU (cheers Colby!). Can anyone help with creating a definition file?
aDe
VR4-rom.zip
98 Legnum VR-4 ROM
(44.51 KiB) Downloaded 891 times
AderC
I can't download rom image...
Postby Nakashima » Wed Aug 29, 2007 12:55 am
How do you downloaded ROM image?
I tried to download the rom image from Legnum VR-4 by Ecuflash ver.1.3.1 yesterday, but error (the same as the error which is the forefront of this topic) presenting, it finished...
Nakashima
Re: I can't download rom image...
Postby Morfeus » Wed Aug 29, 2007 8:24 am
I tried Carisma 1.8 gdi and 3000 gt with ver.1.31 (Evo5/6 item) with Error Window.
I want to ask the same question,
How do you downloaded ROM image??!!
Morfeus
Postby AderC » Thu Aug 30, 2007 5:36 am
Car needs to be in diagnostics mode before downloading the ROM. See my post above on Dec 27.
aDe
AderC
Postby Nakashima » Thu Aug 30, 2007 7:06 am
Car is in diagnostics mode using my Cable.
(When My cable connect the OBD connector, the engine check lamp flushes.)
Why can't I download the rom image from legnum ???
Nakashima
