[14:05:45.341] EcuFlash Version 1.43.3252
[14:05:45.341] OS Version Windows 7
[14:05:45.341] Qt Version 4.6.2
[14:05:45.341] 62 memory models read.
[14:05:45.341] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[14:05:45.513] 356 ROM metadata models scanned.
[14:05:45.513] checksum module "subarudbw" loaded.
[14:05:45.513] checksum module "mitsucan" loaded.
[14:05:45.513] checksum module "mitsuh8" loaded.
[14:05:45.513] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[14:05:45.513] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[14:05:45.513] flashing tool "wrx02" loaded.
[14:05:45.513] flashing tool "wrx04" loaded.
[14:05:45.513] flashing tool "sti04" loaded.
[14:05:45.513] flashing tool "sti05" loaded.
[14:05:45.513] flashing tool "mitsukernel" loaded.
[14:05:45.513] flashing tool "mitsukernelocp" loaded.
[14:05:45.513] flashing tool "mitsubootloader" loaded.
[14:05:45.513] flashing tool "shbootmode" loaded.
[14:05:45.513] flashing tool "shaudmode" loaded.
[14:05:45.513] flashing tool "subarucan" loaded.
[14:05:45.513] flashing tool "subarucand" loaded.
[14:05:45.513] flashing tool "mitsucan" loaded.
[14:05:57.695] Using interface OpenPort 1.3 Mitsubishi EVOSCAN1d468f6d500000000000000000000000000000000
[14:05:57.695] interface close
[14:05:57.710] unable to connect to vehicle interface.
EvoScan 2.9 works fine, but I had to change to MUTIII & set the baud rate to 62500. Searched for but can't find a way or need to set the same under ECUFlash. ECU is not locked. I can use EVOScan to read/verify ECU flash. Win7 control panel says 1.3 cable is working fine. Tried re-installing ECUFlash to no avail. Any suggestions?
