OK a brief description, 2009 AUDM Mitsubishi Triton 3.5L 6G74 V6, ECU: M32r Renasis processor, 32176F4 Family.
I would like to know if it possible for the init code to run direct to pin 11.
I can read/flash my ECU on the bench using the Mitsu init plug running to pin 83 I think from memory on the ECU, this pin runs to pin 11 on the OBD.
Is there a way I can configure this ?
I would also like to be able to reverse this if the occasion demanded......
