- OpenPort 1.3 Virtual Device
Connection to ECU Lost
- "Connection with USB failed" or something like that.
The most troublesome part of this problem, and I feel that it's caused by the same thing - whatever it is - is with ECUFlash, which on total will flash successfully only about 20% of the time. When it works it will successfully flash for a period of time, but when it stops working, and will continue to fail for a good deal of time, I get the popular:
- "No Respones to Unknown Code" fault
This started to happen recently about three months ago and I cannot pinpoint what triggered it. Thus far I have ruled out my computer as being the culprit and feel the cable and connections are fine from wiggle testing. I think a possibility may be due to an ECU stored SES fault code. Speaking of which, for some reason may take a day to illuminate the SES light after the fault occurred, is this typical?
Thanks for reading and, hopefully, responding.
