Page 1 of 2
SH7058 vs IDA
Sun May 28, 2006 11:34 am
by LGT-3-6
I don't see an appropriate forum for this or the info so I thought I'd start out with what I (think) have discovered so far, since some of it doesn't seem to be in the documentation, I have to look of all places in gnu packages for the vectors to be defined :/ Feel free to correct me!
SH7058 uses the SH2 instruction set which is backwards compatible with all the SuperH sets above it, SH3, etc. It appears to be big endian, at least NOP's appear after all branch instructions when dissassembling this way, which you would expect.
The structure of the reset vector is as following:
0x00: PC Power on
0x04: SP Power on
0x08: PC Reset
0x12: SP Reset
In our case both are the same, makes sense!
I get a bit of unfolding so far, however IDA stops after a short while... updates later..
Sun May 28, 2006 4:11 pm
by JonnyM
You have to disassemble as SH-4B in IDA since SH-3 does not have floating point support. There's a bit of floating point libraries in the beginning of the ROM.
There is also a lot of nop's , FF's or 00's being used to align subroutines on 4-byte boundaries..
Sun May 28, 2006 5:14 pm
by LGT-3-6
How far did you get it to disassemble? I still haven't found a master loop.
Sun May 28, 2006 5:28 pm
by LGT-3-6
Also SH-3 does have floating point, do you mean perhaps the library in IDA is broken?
Sun May 28, 2006 9:03 pm
by JonnyM
The SH-3 family does not have a FPU !!
see:
http://www.renesas.com/fmwk.jsp?cnt=sh_ ... chitecture
(middle of the page)
The code starts at $0AAC , with 2 calls to hardware init routines and then a call to the application program main routine.
But, the I in IDA stands for 'Interactive' , you can't expect just to push a button and get a complete disassembly.
This is especially true for this type of CPU and it's way of loading data from the litteral areas following the routines.
There is also a lot of call tables in data portion of the code, something that no disassembler can resolve automatically.
And finally, there is the Hitachi taskswitching operating system using these call tables conditionally.
So get of your a..e and do some work now
Sun May 28, 2006 9:31 pm
by LGT-3-6
JonnyM wrote:The SH-3 family does not have a FPU !!
see:
http://www.renesas.com/fmwk.jsp?cnt=sh_ ... chitecture(middle of the page)
Thanks for the info
but
"In addition, the SH-2E supports single-precision floating point calculations as well as entirely
PCAPI compatible emulation of double-precision floating point calculations. The SH-2E
instructions are a subset of the floating point calculations conforming to the IEEE754 standard."
and
"In addition, the SH-3E supports single-precision floating point calculations as well as entirely
PCAPI compatible emulation of double-precision floating point calculations. The SH-3E
Says the programers manuals.. :/
Sun May 28, 2006 10:17 pm
by JonnyM
The only problem beeing that IDA does not have a processor module for the
E (Extended) version of SH-3, and no module at all for SH-2..
So you must use SH-4 to get the fpu instructions disassembled.
SH-4 instructions are downward compatible with SH-2 and SH-3 so all other instructions will disassemble correct as well.
Mon Jul 03, 2006 8:18 am
by ev8siv3
What entry point are you guys using for the SH4B?
Mon Jul 03, 2006 9:33 am
by cboles
You need to look at the vector table to get the entry points.
Wed Jul 05, 2006 3:22 pm
by ev8siv3
Still no luck with entry points here, doesn't quite fall apart like the HC16.
Wed Jul 05, 2006 3:47 pm
by cboles
have you read the vector table info in the datasheets posted on this site?
Wed Jul 05, 2006 4:01 pm
by ev8siv3
cboles wrote:have you read the vector table info in the datasheets posted on this site?
It states 000000-000039F
Wed Jul 05, 2006 4:19 pm
by cboles
take a look at section 6.1.3, Table 6.3:
Table 6.3 Exception Processing Vector Table
Exception Sources Vector Numbers Vector Table Address†Offset
Power-on reset
PC 0 H'00000000–H'00000003
SP 1 H'00000004–H'00000007
Manual reset
PC 2 H'00000008–H'0000000B
SP 3 H'0000000C–H'0000000F
Thu Jul 06, 2006 12:14 pm
by ev8siv3
cboles wrote:take a look at section 6.1.3, Table 6.3:
Power-on reset
Manual reset
- Code: Select all
PC 0 0000 08DC
SP 1 FFFF DFA0
PC 2 0000 08DC
SP 3 FFFF DFA0
I had previously gathered that much.
So from here I've gathered entry points of 0xF554, 0xF8A4, 0xFBD0, 0x10000, 0x103D4, 0x10AF4, 0x11060. These are for the 512k ROM.
Or simply put, mostly the bytes below:
D26E 420B 0009 D36E 430B 0009 D26D 420B
Thanks for the help again Colby! Anything else I'm missing?
Fri Jul 07, 2006 7:47 am
by LogicGateX
I am having the same problems. I though IDA would have the SH7 disassembler in the SDK. I appreciate you guys posting your findings here to aid the process.
